This would benefit from some resistance being placed in the source circuits of the output devices to reduce the chance of thermal runaway. As a head amp I'm sure something like this is OK, though I've never tried anything like this myself.
A note for anyone with boards yet to build: The boards were not designed for verticals - for a power amp DO NOT simply drop in verticals! There will be smoke and tears! Seriously, they could be properly adapted by those who know what needs to be done.
Haha - that's a good warning. I plan to make the BC550 bias Vbe spreader a BD139 flying leads attached to hexFET for temp compensation. Alternatively, using a smaller power supply and lower rail voltages and current limit resistor can also prevent it from running away.
I meant IRF610/9610 in above post. If you want to use a board that can accept vertical hexFETs use the CFH7 - it's all set up with proper Vbe multiplier for temperature compensation. Has same topology, but with simpler resistor based current sources.
http://www.diyaudio.com/forums/solid-state/294834-cfh7-amp.html
Yep, Jeff has it. Lifted input ground. It can be considered optional if found to be unnecessary.
So the combo D1-2/R3 can be left out ?
You have ground loops happening. The lifted input ground is actually there to help with this problem. The best cure for your problem is independent supplies for each channel. This also helps create a better stereo image in most amplifiers. If they are going to share a common transformer you need the input lifted ground to keep supply returns going back through the correct supply.
- VSSA Through-Hole Version by Jason
