200W MOSFET CFA amp
I am getting ready to build the 200W version of this amp this year - hopefully. I have two questions:
1. What current gain group would you recommend for the BD139/140 BJTs - 10 or 16?
2. What are your thoughts about using a switching power supply with the amp - something like Hypex SMPS1200A700 (63Vdc 100 kHz switching frequency)
I do not have intetion to offer any more PCbs for this amp, but here are gerbers for 200W CFA board, balance addin board and PS regulator board.
Have a nice time building and enjoy listening this powerful amplifier.😉
Damir
I would like to have informations from those who have built 100W or 200W versions of those amps from the gerbers I offered free of charge here.
I am using or used both types for years with grate satisfaction, so if any build is there, please put some informations here.
Damir
For sale 200W version. Boards are not finished as you can see on picture. Reason-moving to Dadod A-class variant.
Hi damir, I came across this thread and am interested in the CFA 200W amplifier with IRFP. I have a few questions...
1. What is the real power output of the 200W version up to 4 ohms
2. What IS the slew rate (SR)
3. What are the benefits of a PS regulator vs an analog power supply?
Thanks Roman 😄
Parts availability or substitutes?
Without going through the BOM in detail , is it most likely that substitute semi's are available?? No issue with output devices and most of them!
I'm planning 3x200w mono's and a 100W 4 channel amp and this is just to start, so possibly more later.
First I build is a single 200w mono fully functional and tested and if all is good then continue.
Its important that my devices are obtained from Newark, Mouser or Digikey.
So, for example I don't see 2SC2240?
Before I order boards or any other parts I wanted to check into this.
Great work, thanks!
