200W MOSFET CFA amp
This is PS regulator with MOSFET output transistor. It works similar as the one with BJT output but can provide higher current before the current sensing go on. Maximal current per rail is 20 A and can be set to 17 A if one diode in the current sensor was bridged.
If anyone interested in a PCB, please, let me kow.
Damir
Very nice Damir, how much voltage will it stand? Will it do 100 volts and 20 amps? Again great work...😀
Hi Chris,
It was designed for +-75 V input and the output is about 6 to 7 V lower.
No need for more then that is needed in my opinion, you can have a bit more then 200W/8 with it. If needed more better to go bridged. High voltage transistors are distinguished and high voltage high capacity electrolytic capacitors are expensive.
Building case, the 100W CFA case.
