CFA Topology Audio Amplifiers
Wouldn't Thiele networks (parallel inductor and resistor in series with the output) be more effective with high fequencies? What kind of models does gEDA use? Do they need to be compiled? Will gEDA work on Debian Wheezy without tweaking?
Here is the layout, if anyone wants the dual layer caps I will share them, one leg is on the green and the other is on the blue or top layer. I have them in Layout 6. The current on 2 oz. board is almost 30 amps.
ANY other thoughts and or suggestions and criticisms, I am going forward with the board and SMD's BUT BIG ones, easy to solder for old eyes like mine. Eighth decade coming up fast.😀
