Old 26th November 2012, 07:43 PM   #31
Elvee is online now Elvee  Belgium
Elvee's Avatar
Originally Posted by Bigun View Post
I'm a bit nervous about what I perceive to be a requirement of exponential junctions matching up to eliminate distortions - IF indeed I am perceiving this correctly ?
In this case, the matching requirement is relaxed, it is only static: deviations from static conditions cause uncompensated non-linearities.
By going to the next level (full dynamic matching), some orders of magnitude improvement in performance would be made possible.
Next installment perhaps?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 26th November 2012, 08:23 PM   #32
Elvee's Avatar
PS: in practice in this case it will be even more tolerant: any spread will be diluted over 8 junction voltages, and will primarily result in an offset voltage (moderate) and ultimately in even order distortion.
The topology itself with its very high loop gain is quite touchy, but that's another story.
It is manageable though, with normal precautions
Old 18th December 2012, 04:28 PM   #33
Elvee's Avatar
It is possible to combine this buffer with class AC.
This allows pure class A operation up to 4~5W, and a seamless and distortionless transition towards higher levels, contrary to class AB where the increased width of class A operation costs a higher distortion in the transition zone (compared to optimally biased class AB).
The end result is an even better linearity, in the 10ppb range.
This is for the output stage alone. If it is included in GNFB loop (which is perfectly possible thanks to the low phase shift and wide bandwidth) with a matching VAS, a further 20 to 40dB is achievable, bringing the overall THD to vanishingly low levels.
Old 18th December 2012, 04:43 PM   #34
wahab is offline wahab  Algeria
Quite spectacular numbers , Elvee...
What is the difference if real current sources are used.?..
Old 18th December 2012, 08:36 PM   #35
Elvee's Avatar
I haven't tested yet with this particular variant.
But degradation is a certainty, at least if they are used regularly, ie trying to make them as perfect as possible to mimic spice sources.
There are other options though: instead of seeing them as liabilities, they can be made to contribute actively to the overall linearity.
Unigabuf is an example of such a scheme.
I have already explored some of these, in sim and even in reality, and they look promising. In sim at least: the reality is for the moment inaccessible with my old ST1700, even augmented with subtraction techniques, additional filters plus FT with a sound card. I can just test the functionality of the circuits, not their actual perfomance.
That has been another of my axes of research for some years now: coherent measurement of THD buried in a large negative S/N ratio, because virtual constructions do have some appeal, but in the end we have to find ways of making sure they are not simply pipe dreams.
That may in fact be the most difficult part of the job, and at this kind of level, I am not even sure the Ohm's law really holds true: it is based on a statistical assumption of an excessively large number of slow charge carriers in a conductor, but under the ppb level, some early effects of saturation could begin to show in ordinary resistors and even conductors.
Anyway, simulation is the first step: something not working in sim is very unlikely to work in reality. The opposite is much more common.
Old 18th December 2012, 10:27 PM   #36
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Elvee View Post
.... pure class A operation up to 4~5W, and a seamless and distortionless transition towards higher levels, contrary to class AB where the increased width of class A operation costs a higher distortion in the transition zone (compared to optimally biased class AB).....
I don't agree, at least not 100%. Consider multiple parallel pairs of complementary output devices where each pair is optimally biassed Class AB (or B as some like to say). You can design this so that the sum of idle current through all the pairs is as high as you need to allow operation in Class A to whatever power level you want, limited only by cost and practical considerations. The transition to Class B will still be optimal, limited only by device matching.
On a practical level I very much like this approach as I believe reasonable device matching is possible for reasonable cost. It allows the heat to be dissipated by more devices, spread over a larger area of heatsink. It reduces the variation in current through each output device for the same power and load impedance compared with a single output pair. This reduces the distortion.
A downside is increased drive requirements. Roender used a CFP driver in his implementation of this approach (IIRC he had about 2W in Class A before transition to Class B).
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th December 2012, 02:35 PM   #37
Elvee's Avatar
Brute force is always an option, but class AC has more subtle advantages: the bias voltage is an order of magnitude larger, the emitter resistors are also larger and this means the sensitivity to initial inaccuracies or thermal tracking problems is correspondingly smaller: with class AC, you are sure to get your performances without having to parallel too many components and without finicky thermal adjustment and compensation issues.
I agree that a fully automatic bias really is the way to go, but short of that, class AC is already a step in the right direction.
Old 20th December 2012, 10:15 AM   #38
Elvee's Avatar
Here it is, somewhat rationalized, and with real current sources.
The sources are crude and minimalist, but active.
This allows a further improvement in linearity, and also gives an opportunity to compensate for the poor complementary of the output pairs.
The class AC version could also benefit from such an improvement.
Old 20th December 2012, 05:52 PM   #39
Elvee's Avatar
And here is the AC version:
Old 20th December 2012, 10:39 PM   #40
Bigun's Avatar
can you post the .asc file for us to play with ?
Funny how it reminds me of the KRILL amplifier by Steven Dunlap.
Alternative topologies for balanced to unbalanced amplifier Elvee Solid State 15 11th August 2012 06:59 AM
Alternative topologies artu Solid State 43 25th July 2012 08:16 AM
SMPS topologies. sildex Power Supplies 7 29th May 2012 01:40 PM
Comparing 3 topologies hahfran Solid State 19 24th November 2008 08:33 PM
Help me understand the topologies here... Bryan Tubes / Valves 8 18th September 2006 07:08 AM
Copyright ©1999-2013 diyAudio
