New Lineup IDEA - Power Follower/Output stage New Lineup IDEA - Power Follower/Output stage - Page 24 - diyAudio
Old 1st December 2012, 10:58 AM   #231
homemodder is offline homemodder  Portugal
Originally Posted by Struth View Post
Hi Guys
Clearly I do not understand things the same way as you, homemodder. Rather, what I understand is that there is more to BJT performance than mere Ft. Gain flatness over the current range actually used is more important and does not require that this be coincident with the maximum Ft point of the device. In this view, I am joined by name designers whom I respect.
Have fun
Kevin O'Connor
Not more important but as important as is the cob and the early voltage of the device / Low saturation voltage comes to mind in second plane. Gain flatness with maximum Ft is not required but if you want high performance both can be achieved at the same time with clever device selection. Try upping the bias on the driver on any class AB amp and youll hear the difference, especially with the dismall onsemi devices. These should are really only be used with triple EF stages and very high power amps were other devices are unfortuneatly not suitable or exist.
The original Bds have a gain which is just as flat as any toshiba or MJL, as a bonus you get higher beta which is advantageous and you get much improved Ft which is also advantageous. Thirdly the cob is also lower meaning lower high frequency distortion.
Old 1st December 2012, 11:21 AM   #232
Homemodder,
which device pair would make a good substitute for the BDs at similar voltage capability?
And which device pair would make a good substitute for the BDs at a higher voltage capability, maybe upto 150Vce0
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st December 2012, 12:12 PM   #233
The BDs from fairchild are not far off the originals or mje243 and mje253.
Higher voltage youd have to use toshibas, parralel them if you have to, even then much better than the onsemi devices. Another current ex sanyo and now onsemi is 2sa1507 and complement which is comparable to the best toshiba pair 2sa1930 and compliment.
Old 5th December 2012, 11:24 PM   #234
Struth is offline Struth  Canada
Banned
Hi Guys
Saturation voltage is important in a switching circuit when you want low losses, but seems irrelevant in an audio amp. I don't run my amps to clipping, nor do I need to extract that last 100mV of swing from the supply rails.
Jkuetemann, the mosfets in your sim are now obsolete according to Toshiba. However, the K1058-J162 may still be current. They are all close enough to each other in performance to be swappable for the circuit. It is disconcerting to see these obsoletions occur, especially when you have these parts in your inventory; should you use them? keep some as spares?
Fortunately with the plastic packages, the mosfet and BJT pinouts are compatible. So, if you lay out a board for the LU buffer, you can use either technology. Just make a provision for the extra drive or predrive stages, and for gate zeners and balancing caps. Then, if the original mosfets die and cannot be replaced, BJTs can be subbed, or vice versa.
Have fun
Kevin O'Connor
Old 9th December 2012, 09:23 PM   #235
bear is offline bear
expert in tautology
bear's Avatar
Originally Posted by lineup View Post
Thanks. I will add inductance instead.
That will keep the distortion low within the circuit,
and at the same time protect against capacitive looads.
What I have found is that the addition of the inductor makes certain ringing into a capacitive load. Can you hear that? I dunno... Thinking out loud now, I wonder if anyone has done actual distortion measurements with the ringing?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 10th December 2012, 01:11 AM   #236
Bigun is offline Bigun  Canada
Bigun's Avatar
Frankly, I think my hearing must be going because I can't hear anything over 1MHz.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 10th December 2012, 10:41 AM   #237
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Originally Posted by homemodder View Post
No they dont outperform the BDs, please show proof, I will then show proof otherwise. The bd137-140 series has less than half the Cob of parts like the toshibas. They also are much faster, 150Mhz compared to 100 that toshibas can manage. The important factor is that the toshibas need to be biased at 100ma and higher to be able to even reach 100Mhz wheres the BDs do this at 30ma. Where does one usually bias drivers for class AB at, 100ma and up, I dont think so. Further the BDs display hfe near twice as high as any toshiba.
They are only inferior when it comes to VA and SOA, use two in paralell and till their rated Vceo they easily outperform any toshiba or any other make of driver.
I think ST might still be doing these, but not sure of the spec.
They were nice GP devices in their day, but a bit let down by the low Vceo rating.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 10th December 2012, 11:26 AM   #238
dadod is offline dadod  Croatia
dadod's Avatar
I have Philips handbook fro 1974 and it states fT for BD 135/137/139 is 250 MHz anf fT for BD136/138/140 is 75 MHz nothing about Cob.
dado
Old 10th December 2012, 02:09 PM   #239
Bonsai's Avatar
I would no use thm for TIS (VAS) applications.
bonsai
Old 10th December 2012, 02:27 PM   #240
The original philips datasheets state ft of 160Mhz for pnp and 190 for npn but please note that these were taken at vce of 5 volt where nowadays its mostly taken at 10v which makes things look a little better but I believe the ft of the npn part could well reach 250 Mhz at vce of 10v. Thats how good these parts are, a real pity about the max Vce but you could push a paralelled pair to +- 50 volts if you re adventurous. Max Vce is stated open base.
The rest of the info can be had looking at datasheets for bc638/9 ect. The bds are simply these in to126 package, this is what the philips parts are and why the spice parameters are identical for the parts. The onsemi ones however are nowhere close to the originals so I dont even consider them as being bd components.
I agree better vas transistors are available but at least they are much better than mje340/350 which are commonly still found even on commercial products.
New Lineup IDEA - Power Follower/Output stageHide this!Advertise here!
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 10:51 AM
mosfet source follower output stage. Printer2 Tubes / Valves 21 18th January 2013 04:43 AM
LINEUP Input-VAS, idea lineup Solid State 57 14th March 2011 11:33 PM
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 04:16 PM
Cathode follower Class A output stage? Circlotron Tubes / Valves 14 15th May 2003 11:11 PM
Copyright ©1999-2017 diyAudio
