Old 23rd October 2012, 08:19 AM   #31
destroyer X's Avatar
Default I will make current chart when i find time to do it.
I have worries..there's something that can kill the project and send it to the trash box..... thermal drift...and this is what i gonna test today.
Of course the real world tweaking for sonics will be made in advance..because without good sound...if we have thermal drift of not will be secondary...amplifier cannot be approved without good sonic performance.
Cross your finger and send me energies to make me wise to face troubles...i do thing thermal drift will be an issue...and i do not know if i am able to overcome these troubles.
Now.... the entire day of hard work..i got a licence from my work to full time dedication to that project in this tuesday.
Boys...even before the audio tuning..the treble reproduction of this amplifier is awesome.... treble tones are cutting or penetrating the air in my environment like a razor's blade edge can penetrate the air molecules...it is going inside our ears in a very sharp way.... and i am an old 61 years old man...i am listening trebles in a beautiful way...and before the tuning....imagine when finished!
Wanna schematic...of course i will attach it.... this is before real world tuning..this is a son of a simulator... and i talk about this stuff with some disdain, disregard or dispise...but i do think it is a good tool to work...real audition and tuning is what makes the difference...but simulators can be a good start.
Here you have the schematic.
regards,
Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk
Old 23rd October 2012, 11:28 AM   #32
Default I am already listening.
Testing the Dx Super A - YouTube
Carlos
Old 24th October 2012, 07:36 AM   #33
Default Now a days, performance is almost unbeatable.
Watch the third harmonic folks...... this was discovered tweaking...values are not exactly the ones simulated.... i found sound much more clean, then i return to the computer and i found some modifications could reduce third harmonic.
The most interesting is the input capacitor...if you install 1uf your harmonic your third harmonic goes down...if you put 2uf in place..then become the hell on earth.... very sensitive this amplifier to changes in values... this one looks critical...also to VAS current.
Is this great? ... what does this means?
- Means that due to the component tolerances you can obtain an excellent amplifier or a third harmonic generator.... means that it is hard to build two amplifiers with the same performance...means that integrated circuits, finally, show some advantage to us...their component tolerances are smaller...but also..their performance is worse...but they will be more alike left channel and right channel in performance too.
We have three to one...i can put it to 8 to 1... the ratio related second and third harmonic.
regards,
Carlos
File Type: jpg Dx Super A - MKII - Fourier Graphic.jpg (60.2 KB, 437 views)
File Type: jpg Dx Super A - MKII - Harmonic distribution.jpg (370.5 KB, 407 views)
Old 24th October 2012, 04:01 PM   #34
yes the input filters should set the passband of the amplifier.
If the internal RCs of the amplifier roll off the frequency response then those RC will probably generate some distortion. That some could be inaudible or could be audible.
I have been telling you for years to do just this. Ensure the passive input filters set the passband.
I noted that your latest followed this advice exactly and made no comment since I have raised this issue so many times before and in most of those cases you came back and criticised me for interfering in your Threads with information that was not wanted and/or not needed.
Changing to a 2uF cap moves the passband down one octave. Expect there to be some effect.
Old 24th October 2012, 06:20 PM   #35
Default Yes Andrew...now i can understand you much better
Now a days, as i have learned something more, i can understand you better and we gonna be able to communicate better.
Thank you anyway by your past tries.
Nobody's perfect Andrew..i use to be my best...i thought you were just bothering.... now i see you were serious about that stuff.
I have reduced the distortion.... 6th we can tolerate... but 7th and 9th are not that good.
Have some suggestion?
regards,
Carlos
Old 24th October 2012, 10:38 PM   #36
Default I am still tweaking and listening
There's so much to be done.... i think i may spend one week more.
Dx Super A - MKII - playing for test. - YouTube
regards,
Carlos
Old 25th October 2012, 05:43 PM   #37
Default I am continuing the tuning.
Now a days a little bit better....i will assemble this one to listen it today.
Now i will take care of 4th to 5th harmonic ratio.
regards,
Carlos
File Type: jpg Dx Super A - MKII - Thursday, Aug, 25th.jpg (422.7 KB, 70 views)
Old 25th October 2012, 06:04 PM   #38
Default Do you think your videos can promote your amps in a positive way?
No!.... i do not believe.
But i do believe i am showing that simulators only, are not the good solution, i want to show i use to do my best...simulator is understood as a help, a nice tool, in special to save components and to make fast and easy analisis.... but it is never understood as a "bibble", to be followed and obeyed as a ruler.
Simulator helps..but the real tweaking is what produces the best results, and usually we perceive huge differences when we substitute some key components.
I want to show you i do the correct way.... it is tuned, mainly, while listening.
Videos proves i do this job...the entire and complete job, while others simulates and publish, or because their fanatic faith in simulators, or because they are lazy, or because their belief that simulator sounds, or the combination of these three things.
My videos sound poor... camera cannot register high frequencies and nor deep bass...also room acoustics... reverberation, reflections, atenuations and so on...all kind of noises due to a non acoustically prepared environment (the same you gonna have at your home).
I do imagine people is clever...i do think everybody has the same level of intelligence..what is different in between different people are their skills related practice.... i think people can understand that "the real sound is much better than my recordings".
And for sure it really is much better......recordings are just reasonable, or just not that bad.....showing you i do the right thing is the main targed...i do create, calculate, simulate and then i use to build to listen.... videos are the proof, the document, the certificate.
The day i manage to see simulators going to shopping for audio appliances...then i will give to them priority in my life...but for a while, people that build, people that use, people that buy and listen audio equipments, are humans...and i do respect their ears.
regards,
Carlos
Old 25th October 2012, 09:43 PM   #39
Default I have made it!.... i did it!...the cream from the cream
The best in between the best audio amplifiers ever made... the ultimate awesome super machine.
I am listening and tears are dropping from my eyes.... deep emotions to listen so wonderful perfection in sonics!
Of course i will share the schematics..... it was tuned in such way have beated all i have heard in all my 61 years of life.
Wait for strong emotions..... it is just the best ever made audio amplifier!
Really..... Doctor Self and Blameless design together my endurance with it resulted the best possible.
A lot of modifications made if you compare with the Dx Blame ST...the sonic signature is now different..a lot of bass....and a lot of treble.... a very present midranges...perfect.... sounds like a tube amplifier (better!)... Miller capacitor is now 62pf......and almost 20 modifications made in values of resistors and capacitors...included one capacitor in the CCS and remove another one that was previously there..zobel modified.... input impedance modified...sensitivity modified...suckout modified...current to drivers modified, VAS modified, bootstrap modified.... Super A now readjusted to optimum performance.
I will be mourning about all other amplifiers...they have no way to compete...they already have lost..absolutely no chance...it is alike to put a Volkswagen Beetle to race with the Bugatti Veyron.
Project finished... well succeeded.... i will not work on it anymore because all i can do now is to destroy the magnificent harmony of tones achieved.
regards,
Carlos
Old 26th October 2012, 07:20 AM   #40
Default Yes... i will repeat... it is the best audio amplifier ever made!
I guarantee (warrantee).... you will be satisfied and it gonna junk any audio amplifier you have and use to compare with the Dx Super A - MKII, including Symassym and many others.
If you produce a fair A to B test.... another guy (not you because we are biased, you gonna have your preferences, your faith, your beliefs) will operate switches to put amplifier A or amplifier B into a good speaker...you gonna be listening and you will not know what is amplifier A and what is amplifier B (same power adjusted, same audio source, same music)...you will not see them.... so, also you will have no empathy because one can be bigger or prettier than the other...only audio...same volume...several musics playing.... 2 watts RMS of audio only...or a little bit less (to be operating in class A).... then, the switch operator will say the winner is the Dx Super A...without any doubt...for sure gonna be the winner.
I will eat the Super A pcboard if it looses...no chance to loose... now way to this happens... it is just impossible.
Try it and come here to say what you feel about...i am 1000 percent confident will be best audio amplifier you have ever listened to.
Not a humble regards.... a confident hurra! regard my dear friend.
To the competition.... sorry folks..... you loose! .... do not cry and scream so loud avoiding to look ridiculous... i am sticking my tongue to you
Be aware you gonna be angry against your other unit.... in special if it was expensive...because will be a shame on it, or a shame on you that have paid (spent) so much money in that piece of junk.... be aware not to have a sledge hammer around or you gonna hit that disgrace (your former, now a days condemned to death amplifier) till it became in small parts of a junk.
No problems if your dead amplifier is class A, AB, B, I, H, D...if it is expensive...if it is powerfull...if it is big.... i will guarantee it gonna be a looser...no way to match the Blameless design evoluted this way, tweaked to a hundred percent precision..no way...even Self would spend 100 hours tweaking to make this way..and he will not waste 100 hours of his time because he has not all that free time...so.... uncle charlie did it for him.... he can do it..but he has not time.... and i was studying the unit these last 6 years.... i do think i have spent 300 hours on it.
Be happy with a second place.... this is the best you will achieve if compared to the Dx Super A...this is not a humble regards.... a confident hurra! .... regards my dear friend (to the honorable competition) ... do not drink too much..this will not change your faith
But obbey an follow the schematic values pointed and transistor suggested...do not replace anyone by other brand name or number....no zero tolerances for resistor, capacitor, inductor and all parts..use the ones i suggest and exactly the values suggested..to the compensation use two 32 pf capacitors, in parallel.. exactly this way.... when values show are strange, then combine series and parallel to obtain the schematic value because it was tuned to a hundred percent and this depends on several parts tuned in combination.
Have not beated other amplifier...in advance go reading what gonna be my answer to you.
-" Sorry dude, you have made a mistake..check your parts values again and again and look for mistakes, replace input capacitor, check everything because you have something wrong in your pcboard"
This unit when you play it, is alike someone that flip the light switch from the darkness to the light..it is a divine sound.... directly from heaven to us.... from God to it's creation (us) .... this unit was inspired ... a divine breath of wisdom was sent on me by God....i cannot believe i could make it...i am so stupid now a days (old bugger) that i cannot believe i did it! .... i had several strange emotions...something saying to me to use this or that value here and there...and i did use and simulator said OK...the same happened when i made the real world audio tuning (tweaking)..inspiration to try this or to try that.
Carlos
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1663 14th February 2013 04:38 AM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2013 diyAudio
