Dx Blame ST together Dx Super A - Page 100 - diyAudio
Old 16th September 2013, 10:27 AM   #991
meanman1964's Avatar
Originally Posted by Ranchu32 View Post
If you need more power than have a look at Carlos' DX MkIII thread. It has no problems driving 200W into 8R. But you will need a very big transformer: 500VA, 1kVA or more!
And still boards available
Old 20th September 2013, 12:29 PM   #992
destroyer X's Avatar
Default Pcboards already arrived at Juan Vargas home
in Puerto Rico.
Soon you gonna have pictures.
And he will open the group buy.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 20th September 2013, 01:37 PM   #993
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Here are some images of the new boards
Juan
Old 20th September 2013, 08:19 PM   #994
Default Group buy link
Dx Super A and Dx Regulator Group Buy Interest
Carlos
Old 21st September 2013, 08:05 PM   #995
Default Juan is already building his own amplifier
regards,
Carlos
Old 22nd September 2013, 07:31 PM   #996
Hello guys
well I like to share my ideas as always I was simulating how the final project looks like using Google Sketch so I work using millimeters measurements to make the components but some parts I can not make and I use free components from the website data base this is just a "simulation" not and actual way I'm going to do it for me is just reference so you also guys can design your own projects too by seen this help to visualize that, ok here is some images:
I did it as accurate as possible might be a bit different depends on your parts you are going to buy, I hope this help develop more ideas for you guys yes the Dx Regulator will be simulate it too
Juan
audio fanatic only
Old 22nd September 2013, 08:07 PM   #997
still4given's Avatar
If I am doing the math correctly, that heatsing is 12" x 5-1/2". I know you guys have built quite a few of these. Is that enough heatsink for both channels? Also, how much heatsink will the power supply require?
Thanks, Terry
Old 22nd September 2013, 08:43 PM   #998
Default I cannot suggest a heatsink model code Terry...because i use other
method to calculate a heatsink dimension.
but i can make a study, considering a worst case scenario.... so...if you apply, you will have your supply series pass transistors heatsink warm...with less than 10 degrées celsius above the environment temperature.
The size depends on the impedance...or the power your amplifier will drain from the supply.
Here you have something that may help.
regards,
Carlos
Old 22nd September 2013, 09:08 PM   #999
Default Dx Super A heatsink
regards,
Carlos
Old 22nd September 2013, 10:43 PM   #1000
Hi Carlos,
I'm sorry, but I don't understand how to do calculations for heatsinks. I was a carpenter by trade. I understand feet and inches but not dissipation.
What I hope to use is my Antek 5225 transformer. It puts out +/-40Vdc with regular bridge/filter on my house outlet. Do you think this will suffice for the Super A? If so, what size heatsink do you think I will need. I am not looking to blast out the windows of my house. I have many powerful amps, including the MKIII that I am currently building. I am looking to use this amp for normal listening levels through no lower than 4 ohm speakers.
Thanks, Terry
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
