Old 9th August 2012, 01:44 PM   #11
Elvee is offline Elvee  Belgium
Elvee's Avatar
I built a quick prototype of the circuit I gave in the first post.
Here is the amended schematic after "real-life-corrections".
On the dynamic aspects, it does deliver: it is capable of putting out a clean 20MHz, 5Vpp squarewave into a 50 ohm load, which is quite impressive.
Its Achilles heel is the DC accuracy/stability.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 9th August 2012, 08:56 PM   #12
Originally Posted by Elvee View Post
OK, here is the unbalanced-output, wide(r) bandwidth version.
It is good to ~10MHz. Going higher would require real HF transistors.
And as a bonus , a slightly improved version of the original circuit with a more accurate 0V level at the output.
If C1 is omitted, the outputs will behave like a grounded center-tap transformer's secondary.
I deliberately gave the original a common-mode loop that is both weak (low transconductance) and slow (filtered by C1), so that the output behaves more or less like a floating voltage source at audio frequencies, that is, like a normal transformer secondary rather than a centre-tapped transformer secondary. That way you can use the output in single-ended mode without the common-mode loop needing to do anything with the signal, but you also keep the flexibility of using the output in differential mode. The accuracy of the DC common-mode level was rather irrelevant because I could use AC coupling. I designed it for a local radio station that uses both professional and consumer gear, and there it really comes in handy.
Anyway, your single-ended version looks nice and is definitely more suitable for your measurement application.
Old 9th August 2012, 09:02 PM   #13
How about the low input impedance and the resistor-matching-dependent common-mode rejection (which is probably not too bad because you have gain>>1)? Are you only measuring signals from very low impedance sources?
Old 10th August 2012, 07:12 AM   #14
Elvee's Avatar
The low impedance is not a problem, it is a 50 ohm environment.
Having the common-mode dependent on resistor accuracy is not a problem for me (although I would prefer freedom from that constraint).
Anyway, I could also add a second Rush cascode for the feedback, very much like your circuit.
More annoying is the fact that the ultimate low frequency CMMR depends on the matching of Early effect in complementary transistors, mainly Q5 and Q6.
The 2N2222/2N2907 pair is quite good in this respect, they achieve more than 70dB up to 500KHz.
The poor DC stability is annoying too, and adding a DC servo would add a layer of complication.
All this is manageable, but I would like to find something friendlier
Old 10th August 2012, 10:49 PM   #15
50 ohm is a characteristic impedance that isn't used much in audio applications, except in broadcast transmitters. Are you sure you are on topic?
Old 11th August 2012, 06:59 AM   #16
Elvee's Avatar
Yes, because as I said, I am interested in topologies, and I remember having seen some unusual ones on this forum.
Some might be totally unusable above several hundreds of KHz, but others could perhaps easily reach tens of MHz by lowering resistance values, etc
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Tubes / Valves 0 31st July 2012 05:25 AM
Balanced vs non-balanced crossover to power amp (Krell KSA100MKII clone) question stolbovoy Solid State 0 24th December 2010 02:54 PM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Copyright ©1999-2013 diyAudio
