#151 |
Very good, please also order SK75/37,5 four heatsinks. SK75 has two pins for which at least one has to be connected to the GND. Consider it as a el. part on PCB, give them a room, not to touch their neigbours, cause they will be hot.
![]() P.S. ... and the name is Lazy Cat
#152 |
Ultime evolution???
LC, 1mF/10V et 2.2mF/10V will be panasonic FC. Both exist in 10mm diam. Marc
website : http://audiyofield.wifeo.com/index.php |
#153 | |
Marc PS :"s" gone ....replaced by "z"
#154 |
#155 |
Thanks....was possible only beacause your help....when i see first version, i mesure the road to the final one.
Thanks a lot, yet i must go for bom and purchase. With single side i can easy do it at home on standart PCB board 160x140. Just a "last" advice...: i have on hand 4x 22.000µf 63v screw caps chemi-con U32D. Will that be enough for two channel or should i add 2x10.000 per board or 2x 22.000 U32D per bord for smoothing? Marc
#156 | |
4 x 22 mF/63 V is more than enough for two channels at +/-50 V, of course all depends on your's speaker impedance, but for 4 ohm would be OK. I suggest to make the amp as dual mono normally if you have two separate transformers. The PCB looks really great and I have to inform you that there will be some three resistors more on it, I will draw it and explain why. Don't worry nothing special but now is the time and will give us much easier job later.
#157 | ||
![]() ![]() Don't know what futur is made from so i think to had 2x10000µf per board. Quote:
Marc
#158 |
diyAudio Chief Moderator
Why you put that remote ''on'' thing? Is it for home theater installations? And how can we skip it locally on board? Maybe better include a 3 way small switch that provides +12V (on), 0V (mute), remote, positions?
#159 |
This update enables TSSA BIGBT HP to be even more universal:
- serial diode MUR160 plus 22 ohm resistor in power supply rails helps to improve PSRR - +/-OPT pins enables to connect separate power supply for the front-end (MUR160 and 22 ohm are omitted) - power supply LED indicators for both front-end and output stage are present - serial compensating resistor added to NTC (serves to calibrate NTC thermal response) - serial resistors added to SK75 heatsink's GND connection (serial RC filter) - 1 uF/63V decoupling capacitors added close to VAS transistors supply rails - TLP627 input now accepts 12 V remote signal (serial resistor added) - LT1034 replaced by TL431 - R2-R9 values stated for +/-50 V power supply rails And that's about it.
#160 | |
![]() No, TLP627 serves to switch output transistors on/off, practically replaces an output relay.
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
