#341 | |
1. A feedback optimisation problem. How can feedback be allocated across stages to minimize distortion, subject to stability constraints. This is essentially a mathematics problem, covered by Bode's theorems, Lurie and Horowitz touch upon this too. 2. An implementation problem. How can the feedback be picked up so as to minimize the effect of the load. This is of course an electronics problem. It is not discussed much in control theory because the load of the sensor is usually trivial. Horowitz mentions that it makes amplifiers a more difficult problem that a similar control system. I think the discussion has been a bit inconclusive because of a failure to separate these issues. TMC appears to lead to a superior implementation in the way it minimises the load on sensitive parts of the circuit. TPC appears to have some theoretical possibility to increase the feedback. In particular I notice that TPC feedback can look more like Bode's plot of maximized feedback. So I want to see if it is possible to retain the excellent load characteristics of TMC and actually improve it even further. Need to understand Edmond's earlier posts on TTMC first. Also reconcile the Harry Dymond TPC paper and Dennis Feucht's TPC notes to produce the correct "Bode fillet" in the feedback. Don't want to beat a dead "TPC versus TMC" horse but the observation on TPC and Bode maximization is new AFAIK. "Has anyone seen this feedback observation before?" ![]() Best wishes David Last edited by Dave Zan; 26th May 2012 at 10:37 AM. |
#342 |
Hi David,
You nailed down precisely why in the past the comparison between TMC vs TPC was subject to much controversy. This was, because we failed to make a clear distinction between a feedback optimization problem and a implementation problem. Thx. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#343 | ||
Do you mean somthing simple like this, far from optimal. Twisted mirror;
#344 | |
one of the few other places I've seen Bode's maximum Feedback discussed - and at least one paper goes a little sideways - probably was unaware of BJ Lurie's work |
#345 | |
I fully agree with that. Yet I can't resist to nitpick on one point, if you don't mind. Strictly speaking, it's the IPS that ultimately limits the performance*, as the non-inverting half of this stage isn't (and can't be) enclosed within the global NFB loop. edit: * Unless someone invents a zero error subtracter. @Pete, thanks for the links. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 26th May 2012 at 01:32 PM. |
#346 | |
It also seems that using the more sophisticated front end topologies, eg cascoded input and Baxandall pair input would help improve the overall LTP performance, due to that lack of feedback to the non-inverting half. |
#347 |
#348 | |
Otherwise, TPC extra loads the VAS, TMC extra loads the input stage - pick your poison. |
#349 | |
Theoretical proofs are indeed important, and provide insight, but they have their limitations. Whether or not this theory is correct, it must make assumptions about the implementation of the amplifier, and other assumptions to just make the problem tractable. Simulation of a real amplifier design is closer to reality than theory, but it also has its limitations. Finally, building a real prototype is still a better indicator, but not necessarily the final word in the general case. Your point about TMC "loading" the input stage probably refers to the fact that TPC provides more gain after the input stage than TMC, since for that aspect of analysis TMC behaves more like straight Miller compensation. Depending on the details of the amplifier design, some designers may be able to do better with TPC. My personal experience, based on many simulations of different amplifier designs, is that my outcome is better with TMC than with TPC when I do the best I can to optimize both, with stability of the two designs held reasonably constant in regard to overall fairness. Your mileage may differ. If they are the same by adding a lead-lag network to TPC (presumably to flatten the closed loop response), why would anyone go for the extra complexity required to make TPC the same as TMC? What counts for me is results that are obtainable in the real world with reasonable effort and reliability, not whether two approaches are theoretically the same. I should also add that I am not a long-time detractor of TPC. I first used TPC in the late 1970's at Bell Labs in the design of operational amplifier ICs that were intended to allow the building of better active filters, such as for Biquad filters (BTW, Jimmy Tow worked for me). TPC was an important tool in making adequate operational amplifiers that had the limitation of slow lateral PNP transistors at the time. Cheers, Bob |
#350 | |
The discussion went over time well beyond some implementation details. It was stated that TMC is "vastly superior", that it is "a first order system" so that's why it offers flat phase, that "it shines" over TPC, etc... etc... etc... But if we agree the only difference (other than personal taste) resides in the cost of a cap and a resistor, then I may concede TMC is superior. It's probably to late for me to think straight, but your statement "simulation of a real amplifier design is closer to reality than theory" doesn't make any sense. Last time I've checked, simulation is theory, so it can't go against theory |
| Bogen Front End | lpd | Tubes / Valves | 2 | 5th March 2008 04:12 AM |
| NE5534 with a new front end ...anybody? | ashok | Solid State | 9 | 2nd June 2006 01:30 AM |
| My New Front End Pics! | micb | Car Audio | 1 | 26th May 2006 02:26 PM |
| Noisily front end | mantistube | Analogue Source | 10 | 16th January 2006 01:57 AM |
| Front end for sub amp | mashaffer | Solid State | 9 | 22nd July 2005 03:35 AM |
