#21 | |
Mike
"We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. " Niels Bohr |
#22 |
mkusan,
1)Did you use MP3 player on battery while testing? 2)you said when no music is played, still some dc appears at the output. well, then was any player like CD or VCD player that runs on mains supply was connected to AMP's input? ( I wish to ask if the ground of other player that operated on mains supply was connected to the ground of this AMP?) 3) did you try physically disconnecting all inputs to the AMP? 4) also try connecting 4.7k resi at the input and ground. for both the channels. and on selector switch select the input where resistor is connected. but with no other device connected.
There is always a first time.... |
#23 | |
2)No, it was easier for me to do tests with mp3 player, but I can try with standalone CD unit 3)Yes 4)Will try and post back One more question for everyone, since there will be a lot of measuring tonight, can I use dim light bulb tester while measuring to minimize my chances of screwing something up or that will render the data useless. Thanks Marko |
#24 |
Bulb tester should be OK as long as the stabilised rails don't drop out (35 volt rail to preamp and the supply to the opamp). Better to have no speakers connected too.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#25 |
would agree mooly...mkusan use a standard 60w light bulb not them energy saver types..
#26 | |
across resistors started 2.3mV but dropped after 3 minutes to 1.5mV from ground to R537 1.4mV to 1.1 after 3 minutes from ground to R531 3.1 dropped to 2.8 after 3 minutes Mora data will follow |
#27 |
I checked C517 and C527, I haven't reversed polarity according to the minus sign on the board and to the photographs of old caps I took before recapping. In circuit capacitance value gives me 4.6uF for C517 and 0.9uF for C527.
#28 | |
#29 | |
hope so, at least.I was tired already but decided to follow your advice on resistors. I measured bunch of them from R539 to R546. Multiple resistors did not have absolute zero on one leg but R546 had 25V on one leg and 12V on the other, and touching that leg (I wore headphones) made a very unpleasant, loud buzzing noise in right channel, none of the other resistors made such noise while tested. R546 is a 330K third resistor from bottom of my picture resistor right to the suspicious one. |
#30 | |
Mike
| dc coupled volume pot value | nightanole | Tubes / Valves | 0 | 7th August 2011 09:38 PM |
| single push volume pot, volume up/down via a button. | dragonxwas | Analogue Source | 4 | 2nd June 2011 06:56 PM |
| Valve buffered IGC - volume pot causes DC offset, crackling | gaplessophile | Chip Amps | 29 | 3rd July 2009 12:02 AM |
| Volume control : - pot' or pot' variable feedback resistor (gain) ? | ash_dac | Solid State | 5 | 1st August 2006 05:07 AM |
| Gain pot instead of volume pot | boyofwax | Solid State | 5 | 14th February 2004 02:37 AM |
| Page generated in 0.12687 seconds (81.59% PHP - 18.41% MySQL) with 11 queries |
