Roender's FC-100 prototype and builder's thread - Page 75 - diyAudio
Old 25th April 2013, 01:45 PM   #741
atupi is offline atupi  Romania
After waiting more than two months for 2SA/SC transistors to arrive i've lost my patience and installed what i had on hand.
The Mje 15034/15035 are 180/220 hfe but the 2SA/SC are a bit worse 140/190 hfe if i remember well.
Old 25th April 2013, 02:02 PM   #742
Rudi_Ratlos's Avatar
Adrian, I used the 2SA / 2SC being manufactured by ISC, when I built my prototype, and I remember that they have done a very good job as well.
Best regards - Rudi
Old 25th April 2013, 05:37 PM   #743
My transistors arrived in the end from Pacific Semi but after a looog wait.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 3rd May 2013, 10:11 AM   #744
A DIY-friend of mine, Andreas, and I are currently working on some improvements of our FC-100 builds.
We installed an ALU U-profile above the transformers, coated with µMetal, to absorb the magnetic field of the transformers.
We will use the top of the ALU-profile to mount supplementary PCBs and components there, for example: an additional bank of small
and fast capacitors supporting the PSUs' - backends, the LightspeedAttenuator PCB, ..., making the FC-100 an "integrated amplifier".
Apropos my Lightspeed Attenuator PCB: this small PCB does a really beautiful job! Its main job is of course to attenuate the music source's signal
(and it does this very delightfully), furthermore it selects the music source, displays the volume attenuation, the temperature of the heatsinks,
mutes, switches off-/on the FC-100, ..., and everything can be controlled by an infrared remote control unit.
I am currently working on a (the final) layout of this PCB that will include a Soft-Power-On circuit as well.
This will be the one that I will eventually offer in a separate group-buy (if there is some interest).
A SYMASYM can be built on a weekend - and that is it.
The FC-100 sounds so gorgeous that you won't stop but try to optimize its sound according to your ideas, experiences, ...
This is very challenging (be sure the FC-100 is worth it) and will take a long time, but this is why I "love" (besides its amazing sound) the FC-100.
Best regards - Rudi_Ratlos
Old 6th May 2013, 06:44 PM   #745
Hi Rudi,
I've Always been interested in your ligtspeed PCB.
Nice work on the upgrade with the U-profile.
Ronny
Old 10th May 2013, 09:12 AM   #746
Ronny, I am doing some slight progress and have annodized (varnished) the ALU-U profile
Find attached the current status of my FC-100 case and a closeup of the current version of the Lightspeed Attenuator PCB.
All of its functions work as designed and produce an adorable sound.
But you know that I am currently working on the Version 2 of the LightspeedAttenuator PCB, the final version that will include SoftPowerOn as well.
So you can do it all, leaning back in your armchair, switching on and off the FC-100, selecting the music-source, controlling the
volume, ..., with the means of your infrared-control-unit.
Old 10th May 2013, 09:28 AM   #747
This is how I fixed the LM35 temperature sensors on the heatsinks, and I have added an additional bank of fast reservoir-caps to each power-rail.
Old 10th May 2013, 12:37 PM   #748
bcmbob is offline bcmbob  United States
Rudi, Have you experienced any vertical shift of the stereo image as the LDRs adjust the volume? Some have reported that effect with other LDR attenuation designs.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th May 2013, 12:50 PM   #749
Bob: I have ordered 150 LDRs for a German group-buy and selected / matched them as close as I could!
See my selection test-rig below.
None of the German DIYers reported about any shift of the stereo image.
On the contrary: they all felt that the Lightspeed Attenuator sounds more "airy, produces deeper bass, ..."
P.S. To make the attached image more clear, I should have inserted a LDR into the SIF - socket.
Old 10th May 2013, 12:56 PM   #750
That's good to hear. From reports by U. Dailey I understand matching can be a big/long process. Looking forward to more information on your final version of the module.
Thanks.
Bob M.
Copyright ©1999-2017 diyAudio
