Hi Friends,
I'm currently finding a new way to design my new integrate amp with zero negative feedback. I heard some audio brands were design their amp like this. What do you think about this kind of amp? Have you ever listen the sound from this kind of amp. I'm only afraid the base quality, because of high amplitude signal might not so well in case of without feedback. Please feel free to share your think here. |
#2 | |
I believe the "zero negative feedback" term normally are referred to a setup without LOOP feedback, but with a lot of local negative feedback. The local feedback factor are determined by the electrical parameters of the active device (Bipolar, JFET, valve) and the emitter / source impedance in some configurations and you may have a negative feedback factor of 10, 100 or 1000 etc.. The tradeoff with high local negative feedback (and thus low distortion) are noise etc..
Mac OS X / Linux, Isolated Hi-Speed (480Mbps) (with automatic LSB extension correction to 32bit for True BitPerfect) USB 2.0 -> I2S (352.8k/384k/32bit) / DSD, JFET powered ES9018 DAC, JFET class A / DSD poweramps, AMT fullrange speakers |
#3 |
Hi RayCtech,
I mentioned on no loop feedback from output to input. So there might be some small local feedback within transistor/JFET Do you have any comment? |
#4 | |
Distortion below 0.005% and so low noise that you cannot hear it Did a test in the early 80ties at a audio dealer: Placed two identical Infinity loudspeaker sets side by side. One set was not connected and one set connected to the amplifier with volume control set to maximum. No music was played = silence. All people did believe it was the un-connected speaker set that was connected to the amplifier as the noise level was highest. The un-connected speaker set picked up room noise due to it was un-connected, but the connected speaker set was "shorted" by the noisefree and low impedant amplifier.
#5 | |
Very good designed, interesting. So what about feeling when you listen the music compare with NF design. Have you published your designed somewhere? |
#6 |
I have built and listened to various GNFB and NoGNFB amps, and can share some observations.
The middle and high frequencies ranges are usually better with NoGNFB designs, especially if they have short signal path. As for the bottom end, NoGNFB amps are a bit more difficult to match with speakers, irrespective of what output impedance they have. One gets impression of a bit not enough articulated bass. I guess, the reason can be in the preferences of speakers manufacturers, they usually use deep GNFB amps during speaker adjustments. Some kind of speakers will be perfect with NoGNFB amps, but there are not so much of them. In the designs, having short signal path and low level and carefully arranged GNFB, the last does not make something bad for the sound, while the amp becomes more universal, it is easier matched to almost any speaker. |
#7 |
I have come to the same conclusions as Vladimirk, for good bass with open loop circuits I find it helps to have a high current, exaggerated (for power Level) multiple output transistor circuit output stage.
#8 |
In this issue, there is something more than simply the output impedance. My last low-level GNFB design, with paralleled jFETs at the output stage, in spite that has a bit higher Zout than NoGNFB disign, gives more articulated bass. It seems that NoGNFB designs, even with mass paralleled power BJTs, have some specific bass signature (I do not say that weak bass, just specific sound signature, a bit less sharply defined), that can be removed only by matching with definite kind of speakers.
#9 | |
I tried mass paralleled power BJTs or mosfets as this is the route taken by designers such as Charles Hanson and recommended by John Curl, I ve come to agree with them that it helps. |
#10 |
Perhaps what would give a good combination is a bi-amping, where the mids+highs are without loop feedback and the bass is with loop feedback. This has been my thinking of late and I am planning a tube amplifier along these lines.
I do feel that the requirements of the mids+highs and bass are different, the speaker drivers are different with respect to their impedance and back emf, and the nature of music transients places some big demands on the bass that are not so common with the highs. Separate amplifiers seems to me a good route for DIY - gives us a reason to build more amplifiers
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Negative Feedback | AmpBuilder225 | Tubes / Valves | 7 | 20th February 2009 08:05 PM |
| Less Negative Feedback Is Better? | CarlosT | Chip Amps | 25 | 14th December 2006 10:18 PM |
| Negative Feedback | Jack Thomas | Tubes / Valves | 6 | 5th May 2003 12:38 AM |
| Negative feedback? | Solid Snake | Solid State | 33 | 14th March 2003 01:29 PM |
| Page generated in 0.11735 seconds (84.87% PHP - 15.13% MySQL) with 11 queries |
