I just purchased a used Crown Com-tech 400 amplifier and after hooking up 2 JBL HSL410's (that work), I noticed that channel 1 is pretty much dead. I am getting a small bit of noise out of the speaker on channel 1 when I play music, however it is barely noticeable and garbled.
I hooked up my equipment in this order: Computer (Creative X-Fi Titanium)->Com-tech 400->(HSL410's/ Jamo Sub 250- in parallel) Note that my Jamo Sub has line-level inputs for amps that do not have a sub out. I have tried disconnecting the sub and reversing the polarity on the speaker wires on channel 1 to no avail. My regular powered computer speakers also work well so this can't be an issue with my sound card. I also double-checked all of the input and output wiring on the amp. I originally had the input wiring connected incorrectly (positive in + and negative in the ground terminal), however I fixed the wiring when I moved the negative wires over to the (-) input terminals of the amp. I am using regular Radioshack Megacable speaker cable by the way. Please let me know if I am missing any information. What is the most likely cause of this problem? I don't mind opening up the amp and replacing components, however I am having difficulty finding where to start. Also, please let me know if I should replace anything (like op-amps) while working on the amp to improve sound quality on both channels. If you would like any pictures of the circuit board, please let me know. Thanks for the help. |
#2 |
I know that bumping threads is frowned upon in many forums, however I disassembled my amp and noticed a blown resistor...
![]() Do you think that I should replace this resistor and power my amp back up or do you think this might be a sign of more serious problems like leaking capacitors? I checked all of the capacitors that I could find but I didn't see any leaking ones. Also, I checked the Schematic from Crown and noticed that this resistor (R701) is on the power control board. Please see page two on the following pdf: http://www.crownaudio.com/pdf/legacy/ct400_main.pdf Thanks Last edited by techbiker; 5th September 2011 at 11:20 PM. Reason: Power Control Board! |
#3 |
The optoisolator (U700) and triac (Q701) should be checked (or repaced) as well. My guess is the triac gate is shorted, damaging the driver and the resistor. Less than $10 in parts.
Candidates for the Darwin Award should not read this author. |
#4 | |
Thanks for the suggestion! I just purchased 2 new optoisolators and triacs (mac224a-4 wasn't available anymore, however I purchased an equivalent part). Considering that one triac failed, I thought that it would be good to replace both with new parts rather than risk another failure. I also purchased new Nichicon and Panasonic capacitors to replace all of the electrolytic ones on the amp. I am having trouble finding capacitors to replace the 2 large 6300uf 200v capacitors however. This type is missing even on Mouser and Digikey! Do you think that it's worth paying around $45 for each replacement (if I can find any)? Also, the sound coming out of the working channel wasn't the best. Should I check and adjust the ODEPs? Should I also thoroughly clean out the inside of my amp? (it's very dusty) Finally, do most people clean out POTs with contact cleaner? I apologize for all of the questions, but I would like to restore my amp to like-new condition. Thanks |
#5 |
A 150V cap will do for 70V mode, a 75V cap will do if you only run it in 8/4Ω mode (and never run it in 70V mode). I wouldn't replace these unless they're all dried up. I would tack a 22µF in parallel with each.
C100, C153 are in the signal path. Parallel C100 with a small value film type, use a good film type for C153. I'm not sure how good the MC33079 is, or what would be a suitable replacement. It's not horrible, I would do the caps first and then give it a listen. I wouldn't fool with the ODEP unless its had some work done on the output stages. I clean pots, switches, and connectors with Caig De-Oxit, it can make a huge sonic improvement. I just bought a couple of 210s and an 810, but I haven't had time to listen to them just yet. Maybe in a couple of weeks.
Candidates for the Darwin Award should not read this author. Last edited by djk; 8th September 2011 at 06:59 AM. |
#6 | |
This is probably a dumb question, but does it matter what value of capacitor I parallel with C100? Should I look for something around .5uf? Also, does increasing the capacitance by paralleling capacitors tend to improve audio quality? Would a 330 volt suppression film capacitor work well in place of c153? PHE841EB6100MR17 Kemet Suppression Film Capacitors I've also heard good things about polypropylene capacitors. Thanks again. |
#7 |
"Wow! Are you considered the wizard of amps? "
Only on Tuesdays, what day is it? I generally buy 0.1µF in bags of 100 for bypassing caps like C100 and replacing caps like C153, I just get any name brand polypropylene (I ordered some Panasonic the other day). That suppression cap is quite large, it may be a fit problem. It's also expensive, the caps I ordered the other day ran $12.27 for 100pcs.
#8 |
Thanks again for the tips.
I actually just finished repairing my Com-tech and the results are amazing. While I cannot say that audio quality has improved at all after installing those new capacitors, both channels ARE working after replacing R701 and Q701. I wasn't able to find MAC224a-4's anymore, however I did find an industry-standard equivalent... the Littelfuse Q2040k7. I thought that this would just be a plug and play, however the new triacs were in a much bigger package (and isolated) and didn't fit in the stock location so I did some fiddling to get them to work. I got the wrong capacitors for C100 (I needed to get non-polarized caps and I purchased polarized ones) and I realized that I needed to replace both C153 and C253 (one .1 uf cap for each channel) so I didn't order enough. Do you think it's worth opening my amp back up just to install caps in parallel at the locations you mentioned? Also, I discovered that my two MC33079's are installed in sockets! I've heard that National makes a very good OPAMP that could replace mine. What do you think about the LME49740? LME49740 - Quad High Performance, High Fidelity Audio Operational Amplifier Have you gotten a chance to check out your Crown amps? On mine at least, the audio quality is pretty darn good. I'll need to wait until tomorrow to really boost the volume. |
#9 |
Here's another update:
I have noticed a hum from my subwoofer (a Jamo 250) at around 100hz. I have made sure that all of my speaker wires are placed a reasonable distance from my power cords and I have checked to make sure that the amp and subwoofer were plugged into power outlets that were a distance from each other. Also, I get this hum whenever I have my amp connected to my subwoofer (regardless of whether or not the amp is on). Once I unplug all of the speaker cables to the sub, the hum stops. I also have the sub connected in parallel to the output connectors on the amp with my 2 speakers since the Com-tech amp doesn't have a sub pass-through connector. Is there something in my Com-tech that might be causing this hum? The subwoofer did not hum when it was connected to the previous owner's receiver at his house. Thanks |
#10 |
Sry, I keep waiting too long to edit my messages. I wanted to add that I get this hum even when I disconnect the inputs to my amp.
| Crown PS-400 power amp is oscillating on channel 2 | Professor Bizzt | Solid State | 3 | 4th June 2011 03:24 AM |
| Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 | tyler477 | Solid State | 1 | 31st October 2008 04:24 AM |
| Crown Micro-Tech 600 | dirtyk777 | Solid State | 100 | 24th October 2006 05:19 PM |
| Crown i-Tech pictures | Evan Shultz | Class D | 5 | 7th November 2004 02:54 PM |
| Page generated in 0.12431 seconds (81.85% PHP - 18.15% MySQL) with 11 queries |
