Simple Symetrical Amplifier Simple Symetrical Amplifier - Page 61 - diyAudio
Old 1st September 2011, 06:45 AM   #601
Idefixes is online now Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by MiiB View Post
I have not done simulation with the BD 140/139 pair.. so I think you must experiment a little..
You can measure the current in the output stage over the fuse..With my driver set simulation suggests something like 250 ohms...(I would use the trimmer to find the right value an than change to a fixed resistor)
Also the resistors setting the Driver stage current can vary a little.. in my simulations (with different drivers) 140 ohm gives app 20 mA which will be just fine..
good luck.
Ok than i will mount 14ohm on socket (that will allow me to replace and tweak easily without desoldering). For R13 I will reduce a little the initial value (300R) and complet with trimmer to find the right value.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 1st September 2011, 06:56 AM   #602
Idefixes's Avatar
Miib,
Won't the actualy fuse place indicate the current in the "SSA" stage and the output stage?
Marc
Old 1st September 2011, 07:11 AM   #603
Idefixes's Avatar
Originally Posted by Idefixes View Post
Miib,
Marc
I self answer me after reading the topic. The mesure across fuse place (replaced by resistor) indicate outpu current by deducting input driver current (2-5mA not significant toward output current) and driver current.
Right?
Marc
Old 1st September 2011, 07:15 AM   #604
Idefixes's Avatar
There is a mistake on my schema and than on my PCB : Q8 ECF20P20 is in the wrong sens Source to V- and not to OUT. I will correct. Thanks Helan for pointing.
Marc
Old 1st September 2011, 08:29 AM   #605
radio is offline radio  Macedonia
Banned
Hi ALL!!
I am finishing this amplifier!!
Give the schematic and makes the final PCB for this amplifier with the transistors pair of outgoing 2SC5200/2SA1943, with power supply Ucc = + /-36VDC.
great thanks and cheers !
P.S.
Hi and cheers Alex !
Old 1st September 2011, 08:39 AM   #606
you have shown capacitors across the rectifying diodes.
You may find that this increases the HF noise that is fed into the PSU.
Allow space to add a resistor in series with each capacitor.
See Hagerman and snubbers, etc.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st September 2011, 08:40 AM   #607
Idefixes's Avatar
Originally Posted by radio View Post
Hi ALL!!
P.S.
Are planing to share pcb and schematic to allows other to try?
Marc
Old 1st September 2011, 08:49 AM   #608
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Exclamation SSA lucky DIY-er
Hi guys.
Nice to see some activity in SSA thread.
Who will be the next lucky DIY-er to experience the sound of SSA?
Regards to all, Andrej
Old 1st September 2011, 08:49 AM   #609
Idefixes's Avatar
Thanks AndrewT, I was thinking so too as an improvement, and for first fire up i plane to not mount 100n caps...I have enough place this serie resistor. I will do this modification.
Marc
Old 1st September 2011, 08:49 AM   #610
Banned
Marc
Hi
Good people (if I understood well) Why not??
thanks
Postscript
Only good and positive people can do such things!
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
