#191 |
Nico, could you please post the schematic that you are using right now ? That is the version i like most by intuition.
#192 |
diyAudio Chief Moderator
Also some info on the bias current used, test rails potential, and the power it achieved for 0.1% THD on 8 & 4 Ohm, will be welcome.
#193 |
I like it in BJT-only form, this has every chance to be a popular circuit.
I find the way you have drawn the schematic adds to the interest for me, not sure I can explain, but it looks nice
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#194 |
It will be even more popular with values given.
![]() So now in this configuration we have 4,3mA input BJT's collector current, 15,9mA driver's current and an output BJT's quiescent current adjustable from 0 to 1,8A.
#195 |
These values are of course discussable, cause now I see that the second stage (driver) voltage gain should be significantly higher, so substantial reduction of 22 ohm emitter resistance must be done. Recalculation in progress ...
#196 | |
as output stage , reducing THD efficently , as displayed in the following graph. IQ is about 0.42A in both cases. |
#197 | |
![]() Please recheck THD with these new values.
#198 | |
than with a double EF final stage. The VAS is really too much loaded and this ruin this circuit capabilities wich are quite good given the schematic simplicity. Good work , Lazycat , anyway...
#199 |
It looks in this concept with 8 transistors, lateral MOSFET output's would give the best THD figures, loading the VAS less than other versions.
MOSFET driver is another option, maybe ... the best solution of this simple concept lies in the right driver/output configuration, as we have already discussed here.
#200 |
How about a BJT - Lateral Mos Szikley compound ? I really would prefer that the mosfets drive the speaker from the drain but i am not a power amplifier specialist.
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
