Old 24th November 2011, 08:32 AM   #1491
a.wayne is offline a.wayne  United States
a.wayne's Avatar
LC, may i suggest another thread for the group buy, better and leave here for the technical stuff.
Old 25th November 2011, 03:39 AM   #1492
SOUND_Rays's Avatar
Originally Posted by Lazy Cat View Post
Hi Sound Rays
Khmm, new sch of yours, khmm, new comments (cannot just say confirmed ):
Please repost all-corrected sch for the last inspection, regards, Andrej
LC,
Thank You for Yours really generous and patient support, my old eyes and late night brains are hardly correlated . . .
I did the changes and will skip the mission impossible, as You enlighten me the chances are really low. I found on a web a similar Mos OP of Mr. Bora design and is to be a good sounding one, maybe interesting to try that OP stage latter. For my the very first try this would be it, maybe also a conventional OP Stage for comparing the real sound difference between the two and chose the most natural one
Thank You,
Old 26th November 2011, 02:06 PM   #1493
Lazy Cat's Avatar
Exclamation SSA BIGBT HP PCB Layout
What do you think about this one boys? Are we slowly getting there? Any suggestions?
Old 26th November 2011, 02:50 PM   #1494
Idefixes's Avatar
Send a message via ICQ to Idefixes
LC will you share you routing job in a another as as GB? I don't need on board Power PSU. I have nice big smoothing Cap (22.000µF/63V), rectifying diode....
Marc
website : http://audiyofield.wifeo.com/index.php
Old 26th November 2011, 03:50 PM   #1495
Esperado's Avatar
Just one, to make-it the way we can cut the printed circuit it in two parts: power supply and amp. Several reason on my point of view: I allways prefer ti share the same power supply for both channels for stereophonic image stability , and i prefer stabilized ones, as i previously mentioned for sonic quality. Last, some people would like to upgrade their existing amp, keeping their actual power supply ?
Just my two cents.
Christophe.
Ultimate Protection
Old 26th November 2011, 04:16 PM   #1496
a.wayne's Avatar
If not seperate as Esperado suggest, i would suggest more room for the capacitor area...
Old 26th November 2011, 06:15 PM   #1497
Idefixes's Avatar
Good news : the NJL4302DG i was wating for are under way. My ThermalTrack version will use couple of NJL4281DG/NJL4302DG. I put you under the latest pcb version bord. Don't hesitate to comment It.
Old 26th November 2011, 06:39 PM   #1498
sonnya is offline sonnya  Denmark
sonnya's Avatar
I would congrat on the layout, you Got the Best possible out of the single layer pcb... But even with the integrated diodes i would have My second thoughts of using only a trimmer for bias......
Old 26th November 2011, 06:55 PM   #1499
Idefixes's Avatar
Sonnya excuse me for my sad electronic knowledge, could you explain more what you mean?
Marc
Old 26th November 2011, 06:58 PM   #1500
Esperado's Avatar
May-be this can reduce a little distortion. (see around output)
Christophe.
Ultimate Protection
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
