Simple Symetrical Amplifier - Page 106 - diyAudio
Old 5th October 2011, 10:49 AM   #1051
Smiley 09's Avatar
I totally agree with Mr. Nico about good analogue sound
Old 5th October 2011, 04:27 PM   #1052
Banned
Originally Posted by Lazy Cat View Post
Look at this, maybe you'll like it even more.
So Crescendo is an amp with the right topology to be easily upgraded to SSA, which opens quite a lot of possibilities for the owners to make a sonical upgrade to their long term companion.
There is only one design situation where your SSA or current feedback cannot be implanted in an existing amp: Where first stage is not symmetrical and has his emitter with a DC offset. But it is not a sSa by nature ;-)
I would like we discuss about the issue with your low values resistances for feedback i encounter in my sims, described in my thread. Can be a global issue ?
Old 5th October 2011, 07:04 PM   #1053
FdW is offline FdW  Netherlands
FdW's Avatar
Default What am I missing?
This is the version that I plan to build, but the fact that the bias current highly depends on the load impedance makes me doubt. Why is this (the varying bias), and can I improve/correct this?
The versions I build will or will not have the CFPs, I will try them both.
The IRFs are at a slightly elevated bias, this is to isolate them from the varying IBs of the power transistors (the simulator tells me that it improves (marginally) by upping the IRFs bias).
As you can see I am planning to build a power supply that delivers 4 voltages (+/- 40V and +/-15V).
Frans.
Old 5th October 2011, 10:34 PM   #1054
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB for SSA LOW IMP HP
...... new PCB for SSA LOW IMPEDANCE HP .....
Alex.
Old 6th October 2011, 12:55 AM   #1055
a.wayne is offline a.wayne  United States
Sin Bin
Alex deh One ...... ....
Old 6th October 2011, 01:35 AM   #1056
Banned
Alex.
Very very beautifull.
Just my two cents: Why don't use 10X1000F instead of those huge 10 000 ? It feat better on board (size and height). it is easier to find. It gives better values (average), it is less expensive, and most of all, each one will have lower ESR & ESL, that will be divided by... 10 !
The only annoyance is, all the 15/20years, you'll have to change 20 caps instead of 2 ;-)
Old 6th October 2011, 02:37 AM   #1057
Sin Bin
presumably , the 10x10,000 is in the psu .......knowing Alex,he is just getting started .....
Old 6th October 2011, 02:43 AM   #1058
SOUND_Rays's Avatar
Thumbs up ALEX . . . PURE BEAUTY of an ART
Alex.
Alex, You become a master of this art, this one is as beauty as it can be, & the only cousin missing here is the balanced one and the family will be complete . . . . . .
Old 6th October 2011, 03:57 AM   #1059
suresh is offline suresh  India
Originally Posted by Nico Ras View Post
Fluid, very transparent, accurate, but not hard on the ears or cynical. In short well behaved music listeners amp
Thanks for your feedback . let me know the important thing's like which transistor pairs should be matched . hfe important or Vbe matchig or both ? what is the output bias current settings and output offset voltge limit.
R.Suresh.
Old 6th October 2011, 08:03 AM   #1060
the OUT location is wrong. You show it from the top end of L1.
It should be OUT at the top of R27/bottom of L1
regards Andrew T.
Sent from my desktop computer using a keyboard
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
