#1011 | |
Hello LC, Can the outputs be substituted with MJW3281A/MJW1302A.. Regards, |
#1012 |
Yes of course, as long as you matched them to hFEmin=100 evenly, so each BJT will flow exactly 1/6 of the output current. These all are based on Toshiba plastic power transistors, very popular ones, so be careful not to buy some sort of fakes.
#1013 | ||
#1014 |
#1015 | |
Could you show us you jig or schematic in measuring hFE of the Power transistors? |
#1016 |
#1017 |
For Lazy Cat:
http://www.diyaudio.com/forums/digit...ml#post2731758 |
#1018 | |
#1019 | |
![]() You can use multimeter with hFE function which calculates hFE=Ic/Ib at Ic=1mA. If you don't have such meter than you can use attached schematic.
#1020 |
Dear Mr. Andrej
You make me the beautiest day since long time awaiting for something to drive my speakers civilized - and You make it. I know, this is the most Generous Scorpio's gift, You give to the whole worldwide sound-lovers & audio community. Thank You ... bless You . . Andreas |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
