Dx Blame MKIII-Hx  - Builder's thread
Old 2nd December 2012, 02:08 PM   #1451
a.wayne is offline a.wayne  United States
Sin Bin
Canonnica ,
Can you post up all your changes with objective/subjective results , currently its scattered all over , a final synapsis on what you have done would help a lot ...
Old 2nd December 2012, 02:09 PM   #1452
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Yep.... tweaked to the bones..... agreed!
I cannot compare using stereo BMW850.... we need same sound entering two channels to compare one channel (tweaked) with the other channel (standard)
regards,
Carlos
Old 2nd December 2012, 02:40 PM   #1453
Default I love these VU meters
DX ST com VUs - YouTube
regards,
Carlos
Old 2nd December 2012, 05:04 PM   #1454
canonnica is offline canonnica  Canada
That's what i'm using since one year. I didn't open it since then. Along with simulation measurements.
Simulations made at full power (1.3VRMS input and 220W RMS at 8R load)
Old 2nd December 2012, 05:08 PM   #1455
Here are the changes I want to implement.
The 56R resistor solely reduces the positive sinus wave ringing present in the sumultaor and confirmed by Bonfis. It does not alter the THD significantly.
The increase in quiescent current greatly reduces THD. The value across the two 0.47R resistors of 54mV is right on with the predicted value of Dr. Self for the lowest distortion level obtainable.
Old 2nd December 2012, 06:30 PM   #1456
As a supplemental reading: http://www.sg-acoustics.ch/analogue_...n_comments.pdf
Old 4th December 2012, 01:43 PM   #1457
Here is an interresting thread on odd and even harmonics to sum up the sonics experience provided by them. It's probably referenced elsewhere on this board: Amplifier harmonics and load stability - Page 3
In defining what would be the best driver base stopping resistor and bias current, I realize that these two elements greatly affects the 2nd and 3rd harmonics balance. I'm now trying (in simulator) to determine what's the best theorical combination to erradicate the odd harmonic distortions while keeping some of the 2nd and other even harmonic ones.
When I'm done, I will implement the change and try to compare in the most objective way (which is not easy... )
Old 5th December 2012, 03:37 AM   #1458
These days, I'm passing a lot of time in simulation. I try to evaluate the best combination vBias and driver base stop-resistor...
I'm exporting tons of fourier analysis into Excel spreadsheet to graph the results. Here is what I've found tonight...
These graphs represents the scenario where the resistor is of 56R in value and I only vary the vBias. The vBias is expressed in mV measured across both emitter resistors of output transistors.
The plot shows harmonics 2 through 9, their scale in on the left. The scale on the right is for the THD line (dark blue one).
I did these plots at a power of 100W RMS as at full power, the readings are scattered and they don't seem relevant. I will try other powers later on, it's very time consuming.
At 100W RMS, the 1st harmonic (reference output signal) has an amplitude of 40, the left axis shows the amplitude of other harmonics.
As I can see, the bias plays a very important role reducing the odd harmonics, which is logical as they're mainly due to crossover distortions. The even harmonics are not varying significantly, except for the 6th one that is quite high at low bias setting. I can't explain it now. I re-did the test several times with consistent results about that one...
I guess harshness is reduced as bias is increased and a warmer sound is expected... but i'm only into simulation right now.
Enjoy and comment!
I will do these plots for other resistor values and other powers as time permits
Martin
Old 5th December 2012, 05:23 PM   #1459
I don't follow.
I see % on the right hand vertical scale.
At the 0.1% level the harmonic for a 40Vpk signal (28.28Vac) should be 1/1000 or about 28mV.
The left scale shows values of voltage of 0.0003V (maybe 0.0002828), this is 0.3mV.
That to me seems to be a discrepancy factor of 100times.
regards Andrew T.
Old 5th December 2012, 05:54 PM   #1460
Sin Bin
Canonnica,
Thanks for posting and I will make the time to go over it all and comment...
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
