♫♪ My little cheap Circlophone© ♫♪ - Page 79 - diyAudio
Old 18th March 2012, 02:59 AM   #781
danielwritesbac's Avatar
Did you reverse engineer a schematic (sketch a schematic from looking at your board and then only after that compare it) for quality control?
Did you check for fake devices, perhaps by swapping in some other suitable devices to see if the large offset problem goes away?
If you visually compare the new board with your working board, what are the differences?
Old 18th March 2012, 03:42 AM   #782
terranigma's Avatar
After posting that, I immediately checked that track again and I saw that my "pull up" method with soldering something didn't get rid of that track properly. So, I removed it by scratching with a tiny screwdriver as what I have to do in first. But, when incidents going to be happen, they are coming faster when you are moving faster. It was totally out of my mind that I removed Q12 and Q13 on pcb. So, guess what happened ..
I have concentrated myself to build a fresh one already. It is not a big of deal for me anyway. I hope that I will last it this time.
Old 18th March 2012, 11:22 AM   #783
Perhaps the next one should use NXP or Fairchild BC560C, BC550C for input?
With the first amp knocked out at Q12 or Q13 and the CFP amps having trouble with BC557, BC547, BC546, I'd have to say that it is probable that you have some counterfeit (or corroded) transistors causing some of these troubles. I also managed to acquire some counterfeit devices since they are so difficult to avoid, especially when shopping for new old stock parts.
P.S.
As for good news, Fairchild, Hi-Sincerity, and Toshiba have PNP drivers with about 26pF that "may" be almost as nice as a Philips BD140.
NXP and Vishay have BAT86 in current production.
ST has 2N3109 (12pF) in current production which is good if your rails are less than 40v; and, Central Semiconductor has 2N3501 (8pF) for $5.50 each and probably workable for high voltage rails.
Fairchild has BC550C, BC560C in current production and also Fairchild has KSC1845 suited for Q12, Q13, in current production.
International shipping from Mouser is $30; however, this is economical since they'll ship a lot of authentic devices in one box.
Old 19th March 2012, 01:54 PM   #784
terranigma's Avatar
As you might know, I have also working builds without any trouble since first run. They have same parts populated. There is always a possibility related with selection of parts but this time it was totally related with an accident.
Btw, sometimes accidents causing to good things to be happen. I applied Elvee's offset trimmer on pcb as an optional feature within a very DIY attitude. I'm planning to test it with this build also.
Old 19th March 2012, 03:49 PM   #785
I'm struggling to find C4-27pF and C12-820pF. Any suggestions or alternatives. I work for RS Components so have a few to choose from
Old 19th March 2012, 06:41 PM   #786
Piersma is offline Piersma  Netherlands
Piersma's Avatar
C4 could be styroflex, NPO, silvered mica.
C12 820pF- 1 nF opt for MKT (or styroflex)
Old 19th March 2012, 09:45 PM   #787
Elvee is offline Elvee  Belgium
Elvee's Avatar
Do you mean you have too much or too little to choose from?
Anyway, these capacitors are not directly critical, they mainly need to be in the right range, and not of a too bad quality.
Since C4 has such a low value, it will be difficult to be wrong: no risk to find an electrolytic with this kind of value. Any ceramic with a defined tempco, silver mica, glass, styroflex, PP, etc is suitable (and overkill).
For C12, the choice is wider. In principle, "noble" dielectrics of the above-mentioned variety are preferable, but the actual impact on performances is very small, and to keep in with the general philosophy of the Circlophone concept, I took great care to use only X7R grade ceramics on all of my prototypes.
You are of course perfectly free to choose other alternatives, including polycarbonate, polysulfone.....
In fact, you just have to avoid high-k, non-linear dielectrics, which is not difficult for this kind of value.
Any improvement can only bring better results than advertised.
. .Circlophone your life !!!! . .
Old 20th March 2012, 06:44 AM   #788
C4, Center tolerance at 26pF, so 30pF 27pF, 25pF, 22pF all work.
C12, Most frequently used values by constructors include: 330pF, 470pF, and more. A wide range of component values will work at C12. Apparently, 470pF is center tolerance.
Result:
C4 = 25pF
C12 = 470pF
Old 20th March 2012, 08:53 AM   #789
Thanks guy's, that helps.
Elvee, I work at the main uk distribution warehouse, we have millions in stock! I was trying to stay with "good" quality components at the exact value which restricted my choices rather a lot.
Old 20th March 2012, 09:17 AM   #790
Elvee's Avatar
I tested the idea of weeding out fake transistors by pushing them to the limit.
Basically, the circuit is a CCS connected to a lab supply adjusted to limit at ~250mA.
The transistor itself is mounted on a ~infinite heatsink: a 5mm thick aluminium slab, thermal paste and and tight clamping using proper hardware.
The operating point is choosen to be well inside the SOA of the real thing, here 160mA and 62V.
With this setup, it took less than 10 minutes for the fake to throw in the towel and go short.
The method is simple and accessible to those having limited test equipment.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
