♫♪ My little cheap Circlophone© ♫♪ - Page 64 - diyAudio
Old 7th February 2012, 05:13 PM   #631
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by danielwritesbac View Post
Thank you! That is a great idea, but I need some help with it.
The added jfet buffer is one way that I could ensure that the amplifier performance remains more likely constant between sources and not have me unnecessarily troubleshooting for a very long time like a puppy chasing its tail until dizzy. Help! How do I install this jfet? Could you provide a schematic example of how to install the jfet to the Circlophone at post 1?
I believe that the added part will help promote reliably repeatable results as well as greater compatibility to various sources of which there is vast variety. And, that variety needs tamed a bit. Jfet buffer?
P.S.
At that point, the very next question would be ideal specs for jfet shopping.
Something like the Pass B1 would be suitable:
www.passdiy.com/pdf/B1%20Buffer%20Preamp.pdf
I may have something cleverer in my "organ bank", I'll make some searching.
. .Circlophone your life !!!! . .
Old 8th February 2012, 12:04 AM   #632
danielwritesbac's Avatar
Maybe sort of like an inbuilt something? Like a streamlined, matching, piece of the amplifier rather than a whole different add-on unit?
Old 8th February 2012, 01:09 AM   #633
What about an op amp buffer? You could give it some gain if you wish, and drive it from zenered or regulated supplies from the main amplifier supply depending how high it is. This would provide very low output impedance and solve your problem very simply.
Old 8th February 2012, 02:14 AM   #634
AJT is offline AJT  Philippines
AJT's Avatar
the amp itself has a loop gain of 200, now that is more than anything i have encountered before....
but a unity gain buffer with high input impedance will fit this amp well.....like the B1....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 8th February 2012, 02:15 AM   #635
AJT's Avatar
good idea.....
Old 8th February 2012, 09:51 AM   #636
Its only a "good" idea if it fixes something,
or simplifies without breaking something.
Therefore I don't pretend to have any good ideas.
Old 8th February 2012, 01:53 PM   #637
Elvee's Avatar
Here is a suitable buffer to match the Circlophone, clever enough not to degrade its performances:
Old 8th February 2012, 04:58 PM   #638
terranigma's Avatar
Anyone building CFP Circlophone ? I wonder if it is going to supersede original one in terms of sonic behaviour. It seems it is not that easy to graphically modify current pcbs respecting cfp modifications.
RC zobel at output reversed in CFP version.. misprint?
Old 8th February 2012, 05:24 PM   #639
Elvee's Avatar
I will try it, one of these days.
Inserting Q7 and Q8 in the LTP should be possible cleanly, with a bit of reflection.
The mod in the feedback cap can be wired "in the air".
Reversed? What do you mean?
Old 8th February 2012, 05:32 PM   #640
terranigma's Avatar
5R6 and 22nF.. 5R6 is connected to output at original but it is connected to ground at CFP. Vice versa for 22nF.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
