#51 |
I really intend to build this thing. I have been getting into designing PCB layouts lately, and I feel I am getting good at it. I gave it a go designing one for this, but gave up about 75% of the way through. Not at that point of learning just yet. I have been doing small preamps, opamp circuits, power supplies and the like. So, If a good final pcb is created, I will test it after a few people (Elvee) eye it up and give it a (preliminary) OK.
I have one important question, though. Elvee, what are good through hole substitutes for the SMD diodes? I can purchase the smd parts and use them just fine, but it seems that the PCB being made here (the only one so far) is going to use through-hole parts. I still have to do an inventory of transistors to see what I've got, but I'm sure I've got the parts I need besides those few diodes. I am comfortable if needed to use the faster devices for the OP transistors and tweak it for stability... another opportunity to learn. |
#52 | ||
There is one small signal schottky, the BAT54. In fact, I should have specified a BAT81 or BAT85, as it is a TH design. It is absolutely non-critical, and any 30V - 200mA schottky will do. There also is a 1N5xxx suitable, but at the moment, I don't remember the type number. If you don't have a schottky available, you could even use a 1N4148. The larger schottky's can be almost anything, BYS45, 1N5820, ... with Imax>=3A. You could even use a fast silicon diode, BYV31 or similar: it would only affect the swing (energetic efficiency) Quote:
And if you confine yourself to calm, placid transistors like the 2N3055, you will not encounter any problem. And when you're confident enough, you can begin to tweak and use faster devices. Basically, this amplifier is designed to be tolerant and undemanding regarding the components. There are one or two things to care about though, f.e. the collector capacitance of Q5 and Q6: if you use high capacitance devices (>20pF), you will most likely ruin the performance. I'll try to come up with a formal builder's guide, to make those (few) things clear. |
#53 |
Banned
circlophone_fix_3B.jpg circlophone_fix_3 - CADCAM.ZIP ![]() w If you see anything else don't hesitate to point it out. |
#54 |
Good!
Everything looks fine now. |
#55 | |
#56 |
Here is a compendium of useful information for would-be builders
#57 | |
#58 |
odysseybmx414, kindly post the pdf of the board...thanks
Elvee, is the schematics of this clever amp can be adopted to Nch Vfets output? I ask since I have bunch of those 2sk's. i want to try building this BJT version and Vfet if possible...thanks |
#59 | |
http://dl.dropbox.com/u/5430178/circ...th%20Drill.pdf http://dl.dropbox.com/u/5430178/circ...Silkscreen.pdf Keep in mind I forgot the layer with the jumper wires. But you can look at wakabaki's posted thumbnail for those. EDIT: Temporarily ignore those. I just noticed what I think is a big error. Wakabaki, your thumbnail shows several traces that are not seperated at all from the groundplane that surrous them. In the gerber files, they do not show up at all. Am I missing something? Last edited by odysseybmx414; 2nd June 2011 at 02:10 AM. |
#60 | ||
♫♪ My little cheap Circlophone© ♫♪ Going from N-darlington to N-MOS is a very small step, it just involves adapting the 120ohm B-E resistors to a value compatible with the G-S threshold voltage of the MOS you use. Very minor indeed. A drawback of this straight modification is that the output swing would be amputated of ~Vth at high current on the positive side, something like 4V. Note that the only types of amplifiers that were actually built are based exclusively on bipolars, PNP drivers and NPN output, the rest is only simulation. Avoiding the asymmetrical swing could be achieved by combining the topologies of the Circlophone and the CircloMOS, but it would be somewhat more complex than merely adapting a resistor value. Quote:
| Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
