My new hybrid amplifier - diyAudio
Old 17th March 2011, 09:38 AM   #1
sajti is offline sajti  Hungary
Default My new hybrid amplifier
I'm workign to build a new hybrid amplifier with tube input stage, and ss buffer. The estimated output power is 300W/4ohms, and the output buffer design based on Marantz PM11S1 output stage. But my version use more and different output devices.
The voltage gain of the buffer is 3. Simulated distortion is 0.003% at 300W output power.
The input stage based on single 6H30P for both channels. Voltage gain is approx. 6.
Sajti
Old 17th March 2011, 09:39 AM   #2
Originally Posted by sajti View Post
I'm workign to build a new hybrid amplifier with tube input stage...
wow!
please show!
regards, Pawel
Old 17th March 2011, 09:42 AM   #3
The schematic of the output stage, with the protection.
Sajti
Old 17th March 2011, 09:44 AM   #4
Sajti
If that buffer is push-pull and includes several stages, emloying tube input stage will insignificantly improve the final sound, it is already determined by the buffer, IMHO.
Old 17th March 2011, 09:47 AM   #5
regards, Pawel
Old 17th March 2011, 09:50 AM   #6
yes it can be. I want to try.
The THD of the output stage is 100 times lower than the THD of the tube driver stage. And the distortion mainly 2nd harmonic.
Sajti
Old 17th March 2011, 09:51 AM   #7
Aikido or White follower at the input?
regards, Pawel
Old 17th March 2011, 09:54 AM   #8
You can use any of them, but not necessary. The input impedance of the buffer is 100kohms, with only few pF input capacitance. I plan to use simple common cathode stage.
Sajti
Old 17th March 2011, 10:02 AM   #9
The PCB with some emitter resistors.
Sajti
Old 17th March 2011, 10:04 AM   #10
The heatsink with the mounted output devices, drivers, and Vbe multiplier.
Sajti
Hybrid Amplifier Design Luck Chip Amps 32 3rd March 2009 02:43 AM
The Perfect Hybrid Amplifier Stee Solid State 0 27th July 2008 08:03 PM
Hybrid amplifier.. Please help.. DoomPixie Solid State 96 2nd March 2006 02:54 PM
Hybrid amplifier help... DoomPixie Tubes / Valves 83 20th February 2006 01:28 PM
HYBRID POWER AMPLIFIER - Please Help! gianmaria Solid State 40 20th May 2005 01:46 PM
Copyright ©1999-2017 diyAudio
