ThermalTrak+TMC amp
ThermalTrak+TMC amp
Old 29th March 2012, 12:16 PM   #71
Bonsai is offline Bonsai  Europe
Looks good! Congratulations!
Old 30th March 2012, 12:44 AM   #72
greenm01 is offline greenm01  United States
Default TT-triple
I've been building the amp in parallel with Dadod, on my side of the Atlantic. He has been very helpful answering my questions and guiding me through my first fully discrete DIY amp. He was kind enough to send me the amplifier PCBs and heatsinks (not available in the USA).
Many thanks, Dadod!
So far I've constructed the power supply, DC regualtor/speaker protection, and almost have one channel complete. After I have the first channel operational, I will begin the second.
I made a parts list, which I've shared on Google Docs.
A few more steps I should be ready for the light bulb test.
Here are a few photos:
Old 2nd April 2012, 11:43 PM   #73
Default Single channel, alive!
youtube A single channel comes to life, and it sounds wonderful!
/Mason
Old 3rd April 2012, 10:33 AM   #74
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
ThermalTrak+TMC amp
Hi greenm01 I added a tag that your link was youtube as there are some members on limited bandwidth or who get logged at work if they go to youtube. No biggy but probably a good idea to tag when you post
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 3rd April 2012, 11:55 AM   #75
dadod is offline dadod  Croatia
dadod's Avatar
Some measuremts here. Sinus 1kHz and 20kHz at a level just below the clipping.
Next are square waves 10kHz and 20kHz on the 8 ohm load.
dado
Old 3rd April 2012, 11:59 AM   #76
dadod's Avatar
Here I put 0.1uF capacitor parallel to the 8 ohm load. First 1kHz and second 20kHz.
dado
Old 3rd April 2012, 12:10 PM   #77
dadod's Avatar
Next is 1uF parallel to the 8 ohm load at 20kHz. Durin the test I overloaded the amp and the power supply protection switched off the power. Reset was done by switch off and after some seconds switch on again, and all worked.
dado
Old 4th April 2012, 04:21 AM   #78
mightydub is offline mightydub  United States
Well done!
I agree with your approach to thermal compensation, I did a lot of (theoretical) study of that approach a while back and it seemed ideal. Looks like it is working very well for you.
"We monitor many frequencies. We listen always. Came a voice, out of the babel of tongues, speaking to us. It played us a mighty dub… "
Old 5th April 2012, 12:36 PM   #79
Default meaurements
Hi, Dado.
The amp is sounding worderful: punchy bass, smooth mids, and aggressive highs. I'm looking forward to completing the second channel.
A few questions in regard to the TT-Triple:
  1. Do you happen to know the input sensitivity?
  2. Have you been able to measure real-world THD?
Also, an unrelated observation/question not specific to this amplifier. On most of my amps, I can hear very low level Johnson Noise (white noise) with no input signal, and my ear pressed up to the speaker. I'm not sure if this is from the speakers themselves, noise from amplifier RC components, or a combination. It's definitely not a ground loop, but low volume white noise. My living space ambient noise is MUCH louder, but I'm just curious about the source of the white noise.....
With headphones I don't notice white noise with line level portable media players and computer audio output.
/Mason
Old 5th April 2012, 01:27 PM   #80
R.I.P.
With the Power Amplifier input shorted you should not be able to hear any noise from the connected speaker.
If you can then the amp has too high a noise level for that speaker.
If my amps measure <=0.1mVac, I generally cannot hear any noise from the speakers I use.
regards Andrew T.
ThermalTrak+TMC ampHide this!Advertise here!
Compact Sized LME49810/11 +ThermalTrak Amp panson_hk Chip Amps 311 15th February 2018 09:25 PM
MEMDIST POWER AMP + JC + TMC - help to set up padamiecki Solid State 8 10th January 2014 09:38 AM
New 200 watt Kit amp features ultra low distortion and Thermaltrak devices snoopy Solid State 56 3rd May 2010 08:42 AM
Mini-Sized 49811 ThermalTrak Amp panson_hk Chip Amps 3 1st April 2010 08:06 AM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
