#2011 | |
Ill probably need a Molecular scientist to explain this one to me.......... Ps I forgot the copperplated version also had copper screws. |
#2012 |
Sakis I understand that the NVA is hardwired, no pc board or circuit board. This would make a difference in to the sound, the quality and material of the board also affects the sound when a board is used.
#2013 | |
Thank you very much!
Group buy DAC-END R (ES9018) full assembled board update 8/5/2013 : https://docs.google.com/spreadsheet/...2c&hl=en#gid=0 |
#2014 | |
with R20 360Ω =50-60 ma Rail +/- 70V 100 ma = 5 W quiescent dissipation per device 50 ma = 2.5 W quiescent dissipation per device Heatsink SK56 Tj, Tc, Ts & Ta? See: http://products.semelab-tt.com/pdf/A...nNoteAlfet.pdf Take a calculator you are good with it. |
#2015 | |
i wonder how my latest product will sound since its made with the bottom part of the enclosure from aluminum ( helps cooling a bit ) while the top is made of iron ....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2016 |
#2017 |
Correct my friend Andrew
I count for 50V +/- rail Regards Nikos |
#2018 |
I think there will be no big issue with metal casing if the main source of radiation (transformer) is outside of the enclosure.
But your toroidal transformer tends to have its magnetic flux confined to its core, so more safe than EI transformer. I prefer to shield the sensitive parts of the amplifier, from RCA to input stage, because the shield material required is few. If necessary the cable is as short as possible. |
#2019 |
I have finished the new version of pcb :
1. The 2n5565 has been modified so that if you have a dip or soic version (LSK389A), you can still use it here. 2. The T3/4, T5/6, T7/8, T9/10 transsistors pairs are re-oriented that they can be stuck to a metal strip for better thermal coupling. 3. The additional T23, T24 can be implemented by using a small piggy board. Please see the attach for new schematic I think someone mentioned using IRFP240/9240 pair by adding a Vbe. Someone please suggest one so I might included this too? Can someone please tell me how to attach more than 1 files to a post? Although I had checked, hope someone can check my work again. I had order of 10pairs at hand. I would start a GB if anyone is interest. BP |
#2020 |
| anyone heard of these? | beauistheman | Multi-Way | 12 | 22nd September 2008 06:49 AM |
| Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? | pkgum | Solid State | 8 | 11th April 2008 01:54 PM |
| ANA Audio Research APA 8 Power Amplifier. Heard of it? | Junior | Solid State | 0 | 1st August 2007 12:56 AM |
| Anyone ever heard of | Staticjeep | Music | 0 | 9th March 2006 02:15 AM |
| Anyone heard of Jam-Tech True Fidelity Amplifier? | tschanrm | Class D | 1 | 17th November 2005 01:10 PM |
