Old 28th April 2011, 07:58 AM   #1661
A second stage with both emitter follower and cascode is prone to local instability, which is indicated by the 50 MHz peak you see. Some randomly placed RC networks may, at least in simulation, mitigate the effect. But a far more powerful technique, used extensively in IC opamps but apparently mostly unknown to audio designers, is the use of a feed-forward capacitor at the emitter follower. For the schematic you posted in the other thread this would mean a capacitor (roughly 100 pF) from the base of Q19 (Q20) to the base of Q21 (Q22).
Also the capacitors from the current mirror inputs (C5 and C6) to ground look dubious to my eyes. Any reason for these? Also I'm not sure if it is a smart idea to implemented the amp without output stage; the second stage output node might be rather sensitive to capacitive loading. Use a small-signal class A emitter follower for prototyping.
Samuel
Old 28th April 2011, 12:22 PM   #1662
Default RC
Hi there,
First of all, I am happy to see Edmond is back on the forum since most of my actual schematic has been discussed with him.
As for the utility of the RC network in simulation it seems indeed rather of lower effect. Or effect in a less important portion of the graphs. However I built once one of those circuits. And also getting back to Samuels comment it indeed helps to lower / annulate oscillations which are like bursts on the scope. I can only guess it is indeed a local oscillation. What I can say for sure is that they have quite effect in reality.
As for the caps to ground in the IPS their effect is indeed very small in simulation and also in my previous pcb, they didn't have any noticeable effect. But I guess they are only useful in case of instability resulting from complex parameters and that in my case they were not needed.
I have a small OPS which is not implemented in this schematic nor in the pcb. I can connect it to the test pcb. I need however a jumper set in the pcb to make it easy. Or I can include the whole stuff on the pcb itself. Mmm I had troubles getting everything fitted on a 100x140mm pcb ... maybe I need to remove fuses and lower rail cap sizes ... it is a prototype anyway and will always be used with a bench powersupply (limited current).
I will check out what your solution brings in the simulation : 100pF between bases of Q19 & Q21 respectively Q20 & Q22
Olivier
Old 28th April 2011, 12:40 PM   #1663
Edmond Stuart's Avatar
Hi Samuel,
Indeed, those feed-forward capacitors are quite effective in suppressing local instability. More recently, by placing caps more or less 'randomly', I discovered this too.
On the other hand, according to Glen Kleinschmidt, a RC network at the input of the VAS serves one more purpose: reducing the susceptibility to HF ingress.
Those caps vastly improve the PSRR at AF/HF. Remember, Cdom is referenced to the supply rails (instead of gnd), hence....
Samuel
That's what I told him too.
E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 28th April 2011, 01:27 PM   #1664
I'm aware of this, but then they also affect open-loop gain. It's been years back since I've looked into this, but IIRC the effect was gross enough to make the technique unusable.
Samuel
Old 28th April 2011, 06:08 PM   #1665
masood is offline masood  India
can anybody will send dr. batra's amplifier circuit/pcb especially.
awaiting curiously masood email khan.shahid251@gmail.com
Old 28th April 2011, 06:13 PM   #1666
Default unusable?
Samuel
At frequencies of interest the effect is virtual zero (at least in this application). Even at 10MHz the OLG is only 0.4dB less. Is that what you call gross enough to make the technique unusable?
E.
Old 28th April 2011, 06:38 PM   #1667
jcx is offline jcx  United States
a quick estimate is that it rolls of 1/2 of the diff pair current starting at the pole of the C with the mirror input resistance
good practice will have some V gain between the diff pair degen and and the mirror degen to keep mirror noise contribution low
so the pole may be ~2-4x below unity gain - but power amps typically are ran at Av ~20 or more so the added pole will typically be 4x or more higher than the loop gain intercept frequency (all assuming dominant pole Miller comp)
the added phase shift at the intercept frequency would be <10 degrees - so the added psrr compensation C at the mirror input shouldn't cut available bandwidth by much either
it could be an unacceptable cost at lower/unity closed loop gain
Old 28th April 2011, 07:03 PM   #1668
It might be that I looked at this for an amp with either low closed loop gain, or unusually high current mirror impedance. Don't recall.
Samuel
Old 28th April 2011, 07:25 PM   #1669
what will be called when npn tr. are in both channel this type of amplifier
plz explain
Old 28th April 2011, 09:16 PM   #1670
Default RC
Hi Samuel,
I replaced the RC network with the 100pF capacitor between bases of the darlington vas transistors. The result is very similar. It eliminates the gain peak @ 50MHz just like the RC network did before.
I am mitigated about implementing both options on the pcb because I am willing to reduce optional tracks as I fear they make opportunities for problems.
Greetz,
Olivier
best audio amplifier book?? Bouvett Everything Else 30 13th August 2012 02:43 AM
Another realization of Bob Cordell's THD Analyzer giulianodes Equipment & Tools 12 3rd August 2010 01:57 PM
Amplifier Design Book pixie Everything Else 27 11th June 2010 08:36 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
book-audio power amplifier by Douglas Self mikee12345 Solid State 8 16th November 2003 01:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
