On ML3 these tone control pots (bass, middle, treble), can I use pots with center point? With all tone pots turned to center position, sound should be unchanged, e.g. same as from source?
UPDATE: Just finished one pair of ML3 for TDA7294 amp and works like a charm. Big thanks, Apex. 🙂
Schematic for preamplifier for sabwufer
Hi
I need a diagram and PCB for an active filter for the subwoofer amplifier: "Quasi amplifier for beginners" (of APEX Audio).
Regulated frequency of 40...120 Hz with a slope of 12...18dB.
This preamplifier that can directly to be connected to output to my stereo amplifier.
Thanks for your help
Hi
Hi apex. I have made apex ml3 pcb. This is the result. Quality is good enough. But i had a little hum, but when i touched the casing of my amp, hum was disappear. Can you give me any advice for it. How to wiring apex ml3 correctly? I just used simple regulated power supply. Thank you very much.
You must grounded your case (gnd from regulated psu connect to amp case)
Thank you very much for your quick reply
In this thread I will post preamps, EQ, active x-overs, VU...
ML3 is Mic/Line XLR preamp with three band EQ +/-20dB
PCB size 100x40mm
Mr Mile,
Can you share pcb lay out in pdf format?
How to make this preamp to 4 adjustable potensio (high, mid, freq and low)?
regards
Endik
Thank you Mr. Mile,
This is my ml3 sound ok but i will add 1 potensio for mid low freq,
can some one help me?
Thank you
ImageShack® - Online Photo and Video Hosting
Thank you
Thank you Mr. Mile,
Thank you
Nice work sir 🙂
Sir Apex...do you have diagram of 3-way active cross-over....?...please post...thankz in advance...
sir mile,
any standard linkwitz riley,is much appreciated 3-way/2way x-0ver,active,
with variable frequency,please sir
please share something for bi amping
Sir Apex,
I have made your stereo tone control.Working very good,But when i turn the bass pot full(100%) it supress the treble,I have used 50k pots.Is there something wrong with this??
I want a 2 way active crossover circuit (12bd/octave) which can work on single supply of 12volt for use in car stereo.I any body have ,please help.
Dear Mile,
Is this correct Sir??
How much current it needs??
No, there is several mistakes.
Mr. Mile, been reading most of your post. Thanks for your time and effort.
Do you have design for echo?? with volume and intensity?? for addition to ML3.
Thank you.
Thank you.
Mixer
Dear Mile...
I was make a new layout of Your tone control with add a XLR con for mic input...I got a plan to make 4 ch mixer with 2 mono input and 1 stereo input but I don't know how to add effect and another block like master and balanced output...
Can You help me to make my simple mixer??
Dear Mile...
Portable version
Mile,
Thanks for this thread!
I'm looking at this for use as a belt pack unit for a friend who plays accordion.
Two channels with all controls. Balanced input and output.
Is there a way to get this functionality with only a 9volt battery? I'm also curious how long it will work if I use two 9 volts?
Many thanks for sharing your knowledge with us.
Chris
Mile,
Chris
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
