#11 |
i belive that the idea is the same with Bob Carver the true sub from sunfire was based on this topology if i remember well ....only legend BOB was thinking about this almost 20 years ago ....
I wonder where is BOB now days ...i think he was terrible when it comes to bussines but otherwise a true mastermind
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#12 | |
The aim for start this thread isn't the needing of pro engineering advices. The aim is only to get basic informations, the degree of establishing in the marked and opinions about this topology. jony: thank you very much for this URL and the schema. Last edited by tiefbassuebertr; 21st April 2010 at 12:00 PM. |
#13 |
well i never follow your posts my dear german friend for a number of reasons ... one of them is that your posts include so many links ( probably usefull ) but god the thing is getting too long .... another think is that my english is ok and my german simply dont exist so yes it is very strange for me to talk with someone that is called tiebassuedertr.... was it something wrong with John or Jim ????
beyond a joke i think you are very right this post belongs here since its not class D to my understanding also to make this more simple to understand i will post one link of the sunfire white paper where Bob is talking about his 1990 dream and how he made it practice http://www.sunfire.com/whitepapers/S...Whitepaper.pdf
#14 |
a bit offtopic
one word for BOB .... once i talked with bob over the phone about one issue for a legend he was actually a very "landed " guy to listen to very willing to understand and share a vision with me later on he supported my idea with documentation and e mails it is not realy importand if the idea put in practice or make money with but still his behaviour was polite and helpfull beyond any expectation ... way to go Bob .... thanks ...
#15 |
Hi tief, it is not that compelxity(typo). It is simple, more simple than classH drivers.
And this regulator different from both carver and labgrupen. EEEngine regulator is based on linear regulator, unlike the other. This linear regulator working as normal voltage regulator. But there is unstable regulator added to help increasing efficiency by helping the voltage regulator. The unstable regulator help to supply the current needed by amplifier. This eeengine low power version (XP1000). Lower power version in powered mixers may be simpler. |
#16 |
It is two interleaved switch instead of single, to achieve better ripple.
#17 |
What software is used by Mr. Ontoaba?
Why do the yamaha amplifiers uses a small silicon transformers? Can these transfomers represent an advantage for amplifiers?. It doesn't be better to use just a smps? |
#18 |
TINA -Texas Instrument, may TINA7 is free version of TINA9, because I feel that it is better than TINA8.
Sorry for late replay. I think the reason was reliability for its lightweight, they still using smps for high power version with over sized (over strengthen) IGBTs. |
#19 |
very good
thank you |
| Class AB, Class AB Non-Switching, Class AB Soft Non-Switching | steph_tsf | Solid State | 4 | 15th March 2010 03:39 PM |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| Class Ab Oposite Topology | sakis | Solid State | 4 | 29th December 2007 01:46 AM |
| DIY Class D topology Question | Rabbedrengen | Class D | 5 | 16th December 2007 05:32 PM |
| Page generated in 0.10777 seconds (76.85% PHP - 23.15% MySQL) with 11 queries |
