500W PA amplifier with Limiter
MUR1620 is single diode, MUR1620CT is dual diode or use BYV42.
why don't you tell me
what is +/-MV and PRO
Hi Emmi !,
Welcome to DIYaudio!🙂
It’s a two step driver circuit. In this amp we are using one more voltage (second step) apart from common +/- rail voltages. +/- MV medium voltage which would less than main rail voltage (HV-high voltage).
"Nothing comes for free... Even knowledge”😀 you have to pay the price.. So just read full thread 82 pages of discussion and have a better understanding about H class amplifier.
Every one is ready to help you on building this wonderful amplifier including Apex (He would be first person)🙄
Vijay
Hi, Apex.
Can you please teel me how many output transistors do I need for +/-42V?
Can I replase MJE15032/15033 with BD243/244 or similar on this voltage?
I have transformer with 2x30v~ sekundar.
Single pair will be ok, you can use BD243/BD244 or use darlingtons BDV83D/BDV84D without drivers. This schematic can help.
gud day
sir apex what would be best replacement for MJE 15033 and MJE 15032?...coz theres no avelable here in our place ...about the .33ohms5w..can i change it to .47 or .22ohms...ang ihave 35 0 35ac transfrmr can i use it for test? than you and more power
regards
jhun
gud day
regards
jhun
Use 2SC4793/2SA1837, and 0,22R/5W. You can use 35 0 35 transformer for test, but zener resistors 2k2/2W replace with 1k/2W.
