500W PA amplifier with Limiter
Old 17th May 2012, 01:04 PM   #2011
wattaniya is offline wattaniya
HI APEX SIR ,
pls verify this gnd wiring.
with full volume, no input signal provided, the hum is coming through speakers , what is the solution?
i checked some professional amplifiers with full volume without input signal and no hum coming through speakers.
Old 17th May 2012, 01:06 PM   #2012
R.I.P.
wrong.
the signal grounds must go back to the main audio ground. The safety Earth is quite different.
regards Andrew T.
Old 17th May 2012, 01:13 PM   #2013
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by nazirdigi View Post
HI APEX SIR ,
Connect wire from PSU GND to the input terminals, and from input terminals to the chassis
Old 17th May 2012, 01:15 PM   #2014
thanks andrewt,
which is main audio GND? (psu gnd or chassis gnd)?
Old 17th May 2012, 01:18 PM   #2015
thanks for the reply.
my input terminals negative metal is already touching to the chassis.
Old 17th May 2012, 01:25 PM   #2016
apexaudio's Avatar
Ok, just connect wire from PSU GND to the input terminals, you can connect 100nF/400V from PSU GND to the chassis but only connect from GND to the chassis must be on input terminals.
Old 17th May 2012, 01:30 PM   #2017
i cant understand,
which is correct?
1-100nf/400v gnd to chassis.
2-gnd to input terminals negative.
3-gnd to chassis.
Old 17th May 2012, 06:40 PM   #2018
B500 TEF ROUTING PCB FINISHED.
starting to make the pcb with silkscreen.
Old 19th May 2012, 07:14 PM   #2019
hi apex sir,
i did what u said in post 2016, now no hum.
my camera focusing is little problem, that's why the images are smudge.
i used these tools to make the casing, taper,taper hande,mini circular saw,drill machine, jigsaw mashine,c clamp.
thanks.
Old 20th May 2012, 09:01 AM   #2020
apexaudio's Avatar
hi apex sir,
thanks.
Thanks for the pictures, what about sound?
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
