Old 30th March 2010, 02:12 PM   #21
wg_ski is offline wg_ski  United States
Originally Posted by sumaudioguy View Post
I suppose if one is locked into the idea there can only be one plus and one minus supply this is a good design- now if you leave that idea behind then... a lot of improvement can be made and a lot of those slow current sources can be replaced by fast resistors. Every current source slows the propagation through the amp.
OK, tell me what makes a resistor "faster", if the speed is limited by how fast it takes to charge a capacitor through it? The overall change in voltage will happen faster with the current source. It may be faster initially with the resistor, but it slows dowwwwwn as the cap approaches full charge. There is no free lunch. In either case, the amp will be in slew limit and distorting. And if we're talking about small-signal response, there is no differnece in speed as it intentionally dominated by a pole somewhere.
Old 30th March 2010, 03:27 PM   #22
apexaudio's Avatar
Thanks to Wahab.
Old 30th March 2010, 05:29 PM   #23
radio is offline radio  Macedonia
radio's Avatar
Pozdrav!
Posto veoma SLABO se izrazavam na engleski hocu nesto da pitam na Srpski:Pitanje-Jel mozes da okacis ovde na ovom sajtu PCB za ovaj pojacavac i nekoliko reci o njegovom zvuku??!
Unapred hvala!
Old 30th March 2010, 05:40 PM   #24
apexaudio's Avatar
Originally Posted by radio View Post
Pozdrav!
Unapred hvala!
Ni moj engleski nije bolji, ali zabranjeno je koriscenje drugih jezika na forumu, posalji PP ili email.
Pozdrav Mile
Old 30th March 2010, 07:26 PM   #25
godfrey is offline godfrey  South Africa
Originally Posted by wg_ski View Post
OK, tell me what makes a resistor "faster"...
Aha! A better question might be "What's wrong with current sources?".
With a simple current source like Q3 in this circuit, the collector-base capacitance is effectively in parallel with the current source, so it's dynamic impedance will reduce at high frequencies.
Perhaps this is why Mile put a 10K resistor in series with it - to keep the impedance high at high frequencies.
Also - The transistor's Hfe, Vbe and Ccb all vary non-linearly with collector voltage, so the current will vary with voltage and will be distorted.
Replacing the entire current source with e.g. a 220K resistor connected to a well regulated +300V supply would eliminate the distortion and high-frequency problems.
For the input stage, these aren't serious problems though, because there is very little voltage swing on the current source and the LTP has good rejection anyway.
The second stage is much more important, but here a Baxandall super-pair has been used for the current source (and the VAS) to eliminate all the base-current distortions.
btw: Neither of the current sources in this circuit will hurt propagation delay, with or without a bit of capacitance.
Sorry for the hijack, Mile.
This looks like a really nice circuit. What rail voltage or power is it intended for?
Cheers - Godfrey
Old 30th March 2010, 07:44 PM   #26
apexaudio's Avatar
Circuit was tested on +/-90V rail voltage, but with single pair 2SC5200/2SA1943 +/-56V is maximum. 80W on 8R load with low THD.
Old 30th March 2010, 08:54 PM   #27
sumaudioguy's Avatar
Sure easy.
First off the current source has its own capacitance in parallel with the gain stage assuring slower response than a resistor. Second if the output transistor supply voltage is say ±50 then the last gain stage can run on -50 (or -75 regulated) and +150 or higher using a very simple voltage doubler and tripler. That resistor then has 150 volts drop to ground and not 50. This also does not increase the voltage requirement of the transistor as when the last gain stage transistor is off the voltage cannot exceed the positive rail voltage plus a few diode drops--- somewhere very near that 50 volts. This also make the amp much more efficient as drive transistor may be driven into saturation. So instead of 120 watts 140 or more may be available.
All amps have slew limiting and so long as slew limiting is out of the audio band there should be no signal to invoke such limit so no slew induced distortion occurs. Slew limit is not related to small signal bandwidth anyway as shown by hundreds of op-amps. Slew limit is only related to large (full power) bandwidth and for audio that is usually defined as 20kHz.
What does this mean? For small signal the resistor biased at the same current will always be faster than a current source at the same current because of the reduced capacitance on the collector to ground. Much higher voltage on the plus supply deals with the bias variation nicely.
Not my idea by the way. Read it in AES journal article by Tomlindsman Hollman I think and several others.
See, very easy once explained.
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 30th March 2010, 09:33 PM   #28
sekhar is offline sekhar  India
hi every body i very new new 2 this field i corrected the circuit as said by wahab and introduced a cap parallel to R20 as I read in G.randy slones book it help in faster turn on and turn off of the transistor if I am correct plz specify the value of the cap and may be the value of R20 needs to be lowered...........
modified circuit
regards
sekhar
Old 30th March 2010, 10:45 PM   #29
Greg Erskine's Avatar
Do a little research on SOAR. I think you may find those voltages are too high.
Greg Erskine
Old 31st March 2010, 07:47 AM   #30
apexaudio's Avatar
+/-56V is maximum for 8R load with single pair 2SC5200/2SA1943.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Good ~100W amplifier percy Solid State 14 10th October 2004 12:31 PM
Page generated in 0.11092 seconds (74.94% PHP - 25.06% MySQL) with 11 queries
