Old 22nd March 2010, 01:58 AM   #1
PB2 is offline PB2  United States
PB2's Avatar
Default Spice Simulation of Adcom GFA-555
I did some quick LtSpice simulations of the Adcom GFA-555 and am making the asc file available here. I was in a rush used good Fairchild transistors for all the small signal devices and plan to substitute correct models as I find them. Used andy_c's output models which are probably much faster but will do for now - thanks andy! This file has SPICE directives to provide analysis of the distortion; use "view" "spice error-log" to see the results.
Remove .txt from the file names to use them with LtSpice.
I quickly collected some models that I had on this system, my main LTSpice install is on another system. These models are in the attached .LIB file. I have many models but probably not for the remaining transistors so if anyone has them please post them, especially looking for the correct outputs.
Pete Basel
http://www.linkedin.com/in/petebasel
Old 22nd March 2010, 02:39 AM   #2
infinia is offline infinia  United States
infinia's Avatar
Thanks Pete got it running in time domain.
I'm working on closed loop Bode plots at the moment
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 22nd March 2010, 02:47 AM   #3
PB2's Avatar
PS caps got in there as 100,000uF should be 15,000uF.
You just uncomment the .ac spice directive, or are you already an LTspice user?
Pete Basel
Old 22nd March 2010, 02:51 AM   #4
djoffe is offline djoffe  United States
Default Is there a resistor missing?
I notice that only Q1 has an emitter resistor, but not Q2? Is this the way the design is, or is there an omission?
Old 22nd March 2010, 03:21 AM   #5
infinia's Avatar
got closed loop bode plot working fine
having trouble breaking the loop for open loop shows neg gain. LOL
Old 22nd March 2010, 03:36 AM   #6
PB2's Avatar
I believe that there is an example in the audio amp tutorial LTspice file. Comes with the installation. I don't think it uses any of the advanced methods. There is a "loop probe" that is probably more accurate discussed here, see andy's post #29:
Open loop gain, phase margin etc
and here:
Spice simulation
Are you a member of the Yahoo LtSpice user's group?
Pete Basel
Old 22nd March 2010, 03:37 AM   #7
PB2's Avatar
Yes that is how it was designed.
Pete Basel
Old 22nd March 2010, 06:22 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi Pete,
Yes, it was. I'll back you up on that.
I wish I had the time to learn how to use spice. It's great that you can.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 22nd March 2010, 02:29 PM   #9
PB2's Avatar
Updated .asc file, fixed supply caps, and added SPICE directives to turn off compression for distortion measurements.
Pete Basel
Old 22nd March 2010, 09:09 PM   #10
PB2's Avatar
LtSpice wiki:
LTSpice and What the New User Should Know - diyAudio
Pete Basel
Adcom gfa 555 help 406vette Solid State 34 15th October 2011 03:34 PM
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 03:42 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 10:20 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
Page generated in 0.11285 seconds (75.43% PHP - 24.57% MySQL) with 11 queries
