New Class A, Super-A, Non-Switching : need a revival ?
Hi Havenwood,
interesting amplifier you dug up. It's always nice to see the many engineering advances made over time. The Denon is claimed to be a non-feedback design. This is not the same as a non-switching design.. Both technologies may help to arrive at a 'perfect' amplifier, but the approach is much different: non-switching ideally prevents cross-over distortion (when the output goes from + to - or from - to +) while non feedback variety prevents the multitude of intermodulation and harmonic distortions that can surface with limited amounts of negative feedback applied in an amplifier. Often less FeedBack can be applied than desired because of limitation in real world components the amp is build with.
regards, Mark
For what it's worth, I rather like the class-AB bias loop principle that the Electronics Instrumentation group of the Delft University has used since 1976. Basically you sense the output currents of the output devices, pass them through a non-linear network and increase or decrease the current through both devices until the output of the non-linear network matches some set value. The non-linear network is typically some smooth approximation of a minimum selector.
I used this technique in 1994 to build a non-switching, adjustment-free amplifier with cheap BUZ10 output transistors - which appealed to me a lot because I didn't have much money back then. The LT1166 is another example of this technique, as is the Circlophone on this forum.
I haven't a clue whether the distortion figures are larger or smaller than with a more conventional amplifier, nor do I care - worrying about specifications sounds like work to me rather than like hobby.
Good implementation is even more important.
from my exprience I have clone m9as2, tried putting it on class a, vs class ab. Sound quality wise very similar to operating at class b.
Added regulator vs without regulator for clone, no diffrence heard.
However with very high quality schematics that I had designed. All the diffrence can be heard from regulating and class b to a.
The clone and other so call high quality schematics they sell is so poor that I'd listen to nothing instead.
Monolithic operational amplifier design with improved HF behaviour
J.H. Huijsing ; F. Tol
Abstract:
The design of a monolithic operational amplifier, which combines a large bandwidth and a high output current, is described. The output stage is equipped with n-p-n transistors only, biased in class-AB by an internal common-mode feedback loop. The intermediate stage consists of a unity-current-gain split-frequency-band voltage level shift. An integrated version, intended for driving 50-/spl Omega/ coaxial line systems, achieves a bandwidth of 25 MHz and 100-mA output current. The principle described provides the possibility for achieving higher output currents.​
All-NPN output stages were popular in April 1976 when this was published, but modern fabrication processes include acceptable PNPs, and modern opamps now employ PNPs in their output stage.
The mysterious node "S" that appears throughout Johan Huijising's schematic, is circled in red in the bottom right corner. Click on the white X shaped icon in the lower left corner, to see the image fullsize without compression distortions.
_
Probably S stands for the P-type substrate that needs to be connected to the negative supply to keep all transistors isolated from each other.
The interesting bit is that the class-AB biasing is handled by the non-linear common-mode loop rather than by the output devices themselves. This makes it independent of temperature variations of the output devices and it allows one to use output stages that are not voltage followers - such as the combined common-collector/common-emitter stage used by Johan H. Huijsing and Frans Tol or a complete common-emitter (or common-source or common-cathode) stage.
By using a different non-linear network you can also implement whatever control law you want to have. I used an exp(-I1*R) + exp(-I2*R) = constant type of law for my non-switching amplifier.
