My new project. On motherboard PCB are PSU 0,+/-100V and 0,+/-15V; Soft-Start for X-former; DC and Anticlick speaker protect; Balanced/Bridge circuit and two Amplifier driver who can run all kind output stage Bipolar, Darlington, Mosfet with Complementary or Quasycomplementary circuit.
#2 |
Hi Apex, have you used this inputstage successfully in a amp, Q6 and Q8 can give a lot of instability and oscilation, what kind of compensation do you use with this setup ??
#3 |
This mini PA Amplifier use the same circuit with four BDW83D/BDW84D darlington outputs. Driver power suply is +/-50V up to +/-120V DC, and is have much stability than clasical circuit with single tansistor in VAS. Compenzations are R5,C3,C7.
#4 |
This amplifier module named Kelvin is made for testing driver circuit. There is no VI limiter just fast fuses. Work with +/-56V DC PS.
#5 |
Made for testing, and now this is my favorite home amp. Powerfull, great sound.
#6 |
Hi Apex, can you give component values, Id like to simulate this one because of the unusual vas. You have compensated it in a different way I have seen such a vas stage done, the only manufacturer I know of that uses this setup is Yamaha in their subwoofer amps.
This type vas loves to oscilate in the Mhz range. Why dont you use driver for the output transistors. |
#7 | |
Agree. Shunt compensation doesn t work well on simple differential topology. It work best on symetrical differentials. I published such a schematic by there, it s somewhere on the old pages, and there s scores published on the net as well. |
#8 |
This design is not so much about the shunt compensation although this vas might work using it, its a baxandall superpair setup, most linear stage Ive tried but problems with oscilation. There is a couple of threads dedicated to try stabilize this type vas.
#9 |
R1-1k
R2,R11-22k R4,R6,R7,R8,R16-560R R5,R10,R14,R15,R17,R18,R19-220R R9,R12,R13-100k Emiter resistors-0R33 5W C1-10uF/25V ELKO C2-100pF KER C3-1500pF KER C4,C5,C11,C12-2,2uF/63V ELKO C6-100uF/25V ELKO C7-330pF KER C9,C10-220pF KER C8-100nF MKS D1,D2,D3-1N4148 Q1,Q2,Q3-2N5401 Q4,Q5,Q7-BC547 Q6-BC557 Q8-MJE340 Q9-MJE350 Q10-BD139 Q11,Q12-BDW84D Q13,Q14-BDW83D I use 100nF KER beetwin input GND and power GND (not stufed on photo) if need to compensate HF oscilation, but not need in this case. Output transistor are darlingtons. Last edited by apexaudio; 7th March 2010 at 10:41 AM. |
#10 | |
Will try some sims of this Vas when i ve some time left, as i ve got other things to sim currently... |
| Serious clipping from motherboard soundcard | chris661 | PC Based | 3 | 21st September 2009 02:12 PM |
| from wich brand is this motherboard | brooks1 | Digital Line Level | 2 | 2nd February 2009 06:12 AM |
| Nice motherboard | DragonMaster | Everything Else | 1 | 4th February 2007 07:02 AM |
| Asus Motherboard | herm | Everything Else | 5 | 3rd January 2007 09:11 AM |
| please help me understand....SPDIF on motherboard. | Wynand | Digital Source | 2 | 20th July 2006 07:26 AM |
| Page generated in 0.10505 seconds (79.69% PHP - 20.31% MySQL) with 11 queries |
