MOSFET Amplifier IRFP240/IRFP9240 - Page 18 - diyAudio
Old 10th April 2010, 08:31 PM   #171
apexaudio's Avatar
Default Apex hv350
Hv350 sch+pcb
Old 11th April 2010, 10:43 AM   #172
apexaudio's Avatar
Hv350 pcb
Old 11th April 2010, 11:14 AM   #173
Hi Apex,
could you point me to a description of the clip indicator operation?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th April 2010, 11:14 AM   #174
apexaudio's Avatar
With new bias circuit on HV350, bias current can be setup at higer value than HV23. Also with new VI limiter there is no need for cut-out protect on PSU and protect PCB.
Old 11th April 2010, 11:19 AM   #175
apexaudio's Avatar
Originally Posted by AndrewT View Post
Hi Apex,
When peak output voltage is <12V to rail voltage clip led light on.
Old 11th April 2010, 01:39 PM   #176
apexaudio's Avatar
Default Clip indicator
If no signal on the output of amplifier voltage on point 47k,22k,10R,10uF is 25V to the negative rail, BC546 is on and short circuit led diode, current go thru GND 10k1W CE of BC546 to negative rail. When voltage on output is about -65V (-75V rail voltage), voltage on point 47k,22k,10R,10uF is 10V to the negative rail, and in the point 22k,1k5,base BC546 is 0,6V to the negative rail, BC546 off current go thru GND 10k1W led to negative rail, and LED light. 10uF give some time delay for short peaks. Sorry for my English.
Regards Mile
Old 12th April 2010, 05:54 AM   #177
apexaudio's Avatar
I prefer stability in amplifier, who prefer value with 10pF instead 100pF amplifier have perfect square at 20kHz, but I do not recomended.
Old 12th April 2010, 06:43 PM   #178
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
hi apex kindly send me the pcb desin for #27 thanks
Old 12th April 2010, 08:10 PM   #179
apexaudio's Avatar
If you post some pictures of your diy work, I will consider about that.
Old 13th April 2010, 02:34 AM   #180
apex,
do you have quasi design for fets
i have a bunch of 2sk's
IRFP240&amp;IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 09:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 02:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 11:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 03:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 01:38 PM
Copyright 1999-2017 diyAudio
