DIY Curve Tracer for PC
Old 11th June 2010, 03:19 AM   #41
EUVL is offline EUVL  Europe
Already with English manual ?
Do you still have a parallel port software in English ?
I still want to use parallel port, as I don't want to sacrifice the measurement speed.
Patrick
PS Mark will contact you to get an RS232 adapter to try out.
Old 11th June 2010, 08:05 AM   #42
locky_z is offline locky_z  China
There are not English manual.
And English Version parallel port software had not writed.
Beasure the parallel port borad no mcu and no Encrypt, everyone can clone it,So I put a limit in parallel port software.
You need a serial number to register, Otherwise it only measure one track.If you change you CPU or harddisk,you must register again.
The RS232 version need my "RS232 adapter", and the adapter have a microcontroller ,so it is no easy clone.
So I remove the register limit on RS232 version software. You can copy to all PC to run.
The RS232 version software have the same measurement speed when Communicate at 115200bps. and less CPU utilization.
If you need more precise (set at over 4 times Sampling),the rs232 version will fast then parallel port version.
Old 12th July 2010, 05:18 AM   #43
oxman is offline oxman  United States
Is there any update on the status of this? I would love to get my hand on one of these!!
Old 27th July 2010, 04:35 AM   #44
new CT version hardware and software have complete.
the version have two board, one is "mcu board", one is "measure board".
DIY Curve Tracer for PC-1-jpg
DIY Curve Tracer for PC-2-jpg
the software not only draw the curve but alse can auto detect DUT's type and pin name.
I will provide the "mcu board",and the "measure board" will not provide.
but the circuit of "measure board" as follower
DIY Curve Tracer for PC-3-jpg
you can designed the PCB base you box.
Old 27th November 2010, 07:01 PM   #45
qusp is offline qusp  Australia
qusp's Avatar
how do I get my hands on one of these? I understand I must design/build second PCB
Old 27th November 2010, 08:10 PM   #46
Tekko is offline Tekko
Banned
You should consider USB. Most ppl nowdays dont even know what a lpt port is because computers dont have them anymore.
Old 28th November 2010, 12:40 AM   #47
parb is offline parb  United States
lpt?! wow, that is a flash to the past, i cant even remember anyone who calls the parallel port the lpt port anymore.... cool!
Old 28th November 2010, 02:24 PM   #48
Complete CT3
Software support English/Chinese language
support USB/RS232 interface
Old 18th December 2010, 05:58 AM   #49
Default new pcb & new schematic
1.three channel power amp
DIY Curve Tracer for PC-jpg
2.power supply and Protection schematic
DIY Curve Tracer for PC-power-suppry-gif
3.USB/RS232 interface
DIY Curve Tracer for PC-usb-rs232-gif
4.mcu conntrol & AD/DA
DIY Curve Tracer for PC-mcu-control-gif
5.PCB
DIY Curve Tracer for PC-pcb-jpg
This version,temperature stable very good
I Short socket B and socket E,and use hot wind the pcb,then measure VBE voltage.
below pic is show the result.
The red curve is checked the "Calibration before measure" option,all voltage is less 1mV.
Another color curve not check the "Calibration before measure" option,the voltage is more then 10mV.
So if you want high precision then check the "Calibration before measure" option,system will spend 0.5s to calibration
DIY Curve Tracer for PC-png
Old 18th December 2010, 12:55 PM   #50
Telstar is offline Telstar  Italy
Great job!
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
