DIY Curve Tracer for PC
Old 28th July 2014, 01:18 AM   #451
locky_z is offline locky_z  China
Oscillation may occur on DUT,
FET when you need to stay away from the circuit board, GATE is generally recommended series with a resistor in order to suppress oscillations.
The tracer B channel output pass through RB/ two relay to socket B.May be DUT oscillation.
Try connect a 100ohm resistor to the Gate and connect to B socket.
Old 28th July 2014, 07:19 AM   #452
generg is offline generg  Germany
generg's Avatar
I had the same experience it seems the two connecting boards are in a way different and "parallel", are they Locky.....?
and the First Wtt is......a really First Class PSS Idea
Old 28th July 2014, 07:22 AM   #453
generg's Avatar
Sorry I read your answer too late....:-)
Old 1st August 2014, 04:50 PM   #454
cwtim01 is offline cwtim01  Hong Kong
cwtim01's Avatar
Originally Posted by locky_z View Post
...Try connect a 100ohm resistor to the Gate and connect to B socket.
Thanks Locky, a gate stopper does solve the issue.
As I'm using a 40V/5A switching power supply, I have replaced the 2 LM358s with LT1013, and the curves become smoother afterwards. If I want to be able to measure current of up to 4A, what value of R50 would you recommend?
Old 1st August 2014, 05:27 PM   #455
cwtim01's Avatar
Default 2SK82 curve
The tracer is capable of measuring depletion mode device like SIT, nice
Old 2nd August 2014, 07:13 AM   #456
I'm not solder the 'protect sw' switch button. you can install these switch button.
When you want measure current more than 2.5A, you can hold down the switch button and begin measure.
This button temporary disable the over-current protect circuit.
Old 5th January 2015, 08:50 PM   #457
Mosaicmerc is offline Mosaicmerc  Trinidad and Tobago
Default Need install s'ware for locky curvetracer
Hi all:
Can u direct me to dl the s'ware for this tracer for win7/64?
Old 6th January 2015, 11:49 AM   #458
Originally Posted by Mosaicmerc View Post
Hi all:
I upload the software and document to yahoo group.
https://uk.groups.yahoo.com/neo/groups/CurveTracer/info
You join the group and can find the software.
Old 15th January 2015, 07:11 PM   #459
dsolodov is offline dsolodov  United States
What is the matching part number for the orange power connector on the board?
Old 5th February 2015, 03:28 PM   #460
ilardi is online now ilardi  United States
I am finally getting around to mounting my curve tracer in a box. I have a few questions:
1) I would also like to know what is the matching part number for the orange power connector on the board?
2)Can you please recommend a tact switch that fits the board holes for the" protect sw"?
3) According to my measurements some of the PCB mounting holes are connected to ground, some of them are connected to nothing and some seem to have an ohm or two resistance to ground. I am mounting the unit in a metal case. Should the mounting holes be electrically isolated from the case?
Thanks.
Terry
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
