Revisited YAP v2.1
Schematic changes since the previous implementation (YAP - Yet Another PowerAmp ) - 4 pairs of 2SK1530/2SJ210 or IRFP244/IRFP9240 as output devices - Improved overload protection (shuts down the entire output stage, thermal budget optimized) - Temperature compensation supports both Toshiba and IRF MOSFET pairs. - Active clipping protection, as per the VSOP amp - Improved OPS input stage (following an idea by Andy). - Output stage uses TMC frequency compensation. - Alexander based input stage with improved current mirrors and Hawksford cascodes supports a variety of opamps, currently running on LME49710 ![]() (These are the board level schematics, the output 1uH coil is dampened by 2.2ohm in parallel; Q114 is shorted for 2SK1530/2SJ201 only). Construction changes since the previous implementation: - Single 3.8" x 9.8" board construction. - Supports both 2SK1530/2SJ210 or IRFP244/IRFP9240 power devices without any changes except the bias adjustment. - 0.4W/C 5" x 11" Ro-Theta heatsink sections. ![]() Measured (preliminary) performances: - Output power: 2 x 200W/8ohm, 2 x 400W/4ohm, up to 2 x 600W/2ohm at +/-65V supplies from a 2KW toroid. - Unity gain frequency: 4MHz - Phase margin: 100 deg. Stable in all loads I was able to test, including 2uF series with 1ohm at 400W output power. - Bandwidth: 10Hz-160KHz +/-0.5dB - Non slewing; Rise fall times defined by the input filter <0.5uS - Intrinsic slew rate >200V/uS - Harmonic distortions: <0.0001% at all frequencies and power levels up to 200W/8ohm - Harmonic distortions: <0.0003% at all frequencies and power levels up to 400W/4ohm - IMD 19+20KHz: <0.0003% at all frequencies and power levels, up to 400W/4ohm. - Ultra clean clipping, no sticking. The PGP amp is there, in the dust. |
#2 |
Banned
Very cool! A few questions...
The 1 Ohm resistors in the emitters of Q110 and Q116 - were they strictly necessary, or a "just in case" thing for the layout? Regarding the 100 Ohm resistors in the collectors of these devices, what was the symptom when they weren't present? I assume parasitic oscillation? If so, roughly what frequency was the oscillation? Is that TMC I see there in the output stage (C112, C113, R126, C123, C122, R158)? What effect do the 47 Ohm resistors have (R120, R164)? Thanks. |
#3 | |
Yes, parasitic oscillation. Frequency was about 60MHz. Even 47 ohm would do, I chosed 100ohm to stay on the safe side. As mentioned above, it's TMC. 47ohm, increases the phase margin a bit (5-7 deg). To large and the phase peaks. 47 ohm seems to be an optimum here. Can be safely omitted but it won't harm to have a placeholder on the PCB. BTW1, TMC is for the heck of it, TPC delivers exactly the same performance (I tested that in detail). BTW2, I'm stumped by people stubbornly using IRFP240/IRFP9240 as "complementary" parts from IRF/Vishay. IRFP244/IRFP9240 is way better matching. In fact, according to my measurements, they deliver the same performance as the Toshiba pairs, at 40% the price. The only down size is with the headroom, the IRF pairs have large threshold voltages, they require Vgs about 4V for bias. The Vgs thermal coefficient is also different, but that can easily be compensated as in the schematic, using Q114. |
#4 |
Banned
Heh. Thanks for livening the place up. It was getting pretty bleak around here for a while there
I'm familiar with the matching issue - you are right. I posted EKV models for the IRFP244 and Fairchild FQA9P25 (I needed the 250V capability in case the line voltage goes 10 percent high). |
#5 |
Wow, this looks really interesting and it's completely unfamiliar to me along with some of the TLA's.
Do you plan to post the Spice file for others to play with ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#6 | |
#7 |
Thanks for the tip about IRFP244/9240's.Two ??'s ... why are the gatestoppers "unbalanced" ( 100R - r114-117 & 150R - r165-168) ?
and what is the purpose of R133/149 (220k)? OS |
#8 | |
Have fun, Hanes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#9 |
So you drive 4 big output mosfets with only ~12mA of charging current (and much higher discharging to avoid cross-conduction)?
How is bias modulation at 20kHz? P.S. Yes, I see C115, this should, to a degree mitigate bias modulation, but at the expense of slew rate. What do I get wrong? |
#10 | |
| A75 revisited | Peter Daniel | Pass Labs | 20 | 16th September 2009 10:19 AM |
| Build or Buy - Revisited... | DIYNewbie | Multi-Way | 15 | 26th June 2004 10:41 PM |
| Revisited Zen | seve | Pass Labs | 6 | 16th June 2004 09:41 PM |
| Zen Revisited mono PCB | Salas | Pass Labs | 1 | 11th April 2004 11:15 PM |
| Page generated in 0.33427 seconds (36.73% PHP - 63.27% MySQL) with 11 queries |
