pre standard two preamp, and development of measurement methods
What do I mean is,
X: frequency,
Y: level of output signal in respect to input signal,
Z: level of input signal.
I see it clearer now, but still not enough, especially what kind of measurement, THD or what? With THD (as a 1-dimensional lumped parameter vs freq) the picture is clear: slices of THD (ref signal level) vs freq, each slice for a different signal level, to see how the THD develops vs level. One would see things like increased THD with low levels when we have crossover distortion, for example. This would be rather easy to create with a bit of software. A set of plots for each individual HD component would also be possible and equally easy.
But with things like IMD it's not so clear anymore, unless we can specify what "frequency" is supposed to mean exactly.
- Klaus
Wavebourn said:
Hi Bob;
nice to see you here again.
Do you know of some measurement system that is capable of drawing waterfalls with levels in decibels of error products in respect to input signal level, with frequency? Such graphs would be very revealing.
Hi Wavebourn,
Thanks. I don't know of such a system, but I would think that with today's PCs and excellent sound cards, something like that could be done, or maybe has been done. This reminds me of some of the kinds of neat software/measurement systems that are used for loudspeaker systems.
Bob
THD means Total, it is useless since more than one topology exists. What I mean, to show levels of harmonics on the 3-dimensional graph, be them single tone products, or products of multiple tones. With such a software you can see how extra products created by a sound reproduction chain depend on level of signal.
If such a software does not exist yet consider this idea as Public Domain.
Sounds like the "waterfall" commonly used to show the decay time vs frequency for speakers?
Except here we want the height of the waterfall to represent the THD product level vs input level??
Dunno, but I think the idea lends it self better to IM tests as the entire spectrum might be "lit up" by the right sort of IM test, then we could see the IM "mountain" change vs input (or output) level??
_-_-bear
Joined 2004
I have used a multitone test for looking at all manner of problems. However I don't find the test above useful. I use the spectral contamination test because the tones have no im or harmonics that overlap other products, nothing is hidden. Its very sensitive on transducers but electronics don't have as much trouble with it.
My lowly Juli@ car has distortion residuals at -115 dB or lower. Not bad for $150. I don't think instrumentation is a big issue today. Its understanding the output. Particularly the cause and effect relationship between circuit design, execution and measurements.
Last weekend I was at the Computer Audiophile symposium and given the opportunity, along with the others who made it, to hear subtle differences in exceptional playback systems. There were differences where by rights there shouldn't be but I felt that ascribing the causes for the differences and even making assumptions about right or wrong in the sound was not based on solid ground. The point being that hearing a difference is not enough to be sure of any cause. In this case there were 4 samples of possibly the best DAC ever made. However that is no guaranty that they all sound the same. Even location on a rack could bring issues that would not be obvious on initial inspection.
The same for opamps. Its possible that layout issues that a 5534 from Signetics(or Philips) would not have a problem with may cause issues with samples from a different vendor. This can lead to assumptions about the generic class of devices. Swapping in a socket is not definitive of anything except for that particular socket. I'll pass my experiences hot rodding commercial distortion analyzers on the test equipment thread.
You got it right. A "mountain" instead of a static picture. I.e. dependence of products of distortions (don't matter which distortions: intermodulation, non-linear, phase, whatelse) in dynamics.
AX tech editor
Joined 2002
Demian, thanks for a nice post. Perceptive.
I am intrigued by that Computer Audiophile symposium. I looked up the Computer Audiophile website but didn't find any report about the symposium. Any info on the type of equipment / DACs that was demo'd?
Thanks,
Jan Didden
Looks like this, e.g.
