#101 | |
I don't need very much power, a lower current might well suffice. For example, I'm currently using a 1W tube amp. At this power level I don't need much above 500mA for SE Class A. e.g. http://www.recom-international.com/p...ine/RCD-24.pdf Nevertheless, the idea presented in this thread is very interesting - I have 4 boxes that were destined for SE Class A which were never finished because the heatsinks weren't 'man enough' - the switching current sink might be my way out...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#102 |
It depend on how fast that LED driver could manage the voltage changing (slewrate) it seems that devices using some output capacitors.
| New class A biasing (with non-switching class AB overflow) | Steven | Solid State | 34 | 24th March 2007 06:40 PM |
| Quick question - possible to build high-power current-source Class D amp? | 454Casull | Class D | 2 | 24th November 2006 10:48 PM |
| Aleph-type current source, but source follower this time | tschrama | Pass Labs | 4 | 29th July 2005 12:55 PM |
| switching regulator as a current source | SS | Parts | 13 | 10th February 2004 01:58 PM |
| Source follower electret mike -> use with current source? | capslock | Solid State | 1 | 28th February 2003 12:54 PM |
| Page generated in 0.06366 seconds (69.16% PHP - 30.84% MySQL) with 11 queries |
