Yes, it makes sense. It has been done before. I can't remember what it was called (there are many here much more knowledgable about that).
What kind of output devices are you using? If you're using MOSFETs, it isn't a good idea, because the low-level resolution will suffer.
Steve
Steve
Its in http://www.diyaudio.com/forums/showthread.php?s=&threadid=11205&perpage=15&pagenumber=32
I call it madness circuit.
nobody special said:a class A p/p amp can put out 2X the idle current before leaving class A.
Should be 1x idle right?
Or where do you get the extra current from?
/Peter
It says 2X idle in the Pass A75 article. That's where I got my info... I think it's correct. Maybe someone can explain why that is. I know I simulated it before, and it made sense, but I can't remember just what happens to explain it better. Sorry.Should be 1x idle right?
I was about to write an explanation, but perhaps a picture
explains it better. Look at the third set of pictures in
http://perso.wanadoo.fr/jm.plantefeve/mont.html
All text is in French, but I guess the picture is self-explanatory.
I think so too. Imagine the upper and lower transistor are both sitting at 5 amps. Then the amp starts to pull up the load by 10 amps. This means the upper transistor current will go from 5 to 10 amps and the lower transistor will go from 5 to 0 amps. 0 amps is the point it would move out of class A if you went further. The upper transistor takes on 5 extra amps while at the same time the lower one relieves the upper one of 5 amps. Add positive five and subtract negative five. Therefore you can sourced or sink double the quiescent current and stay in class A, IMHO.nobody special said:a class A p/p amp can put out 2X the idle current before leaving class A.
This just shows that you'll need more than 1 x idle to stay in classA, since, in the above example, the lower transistor will be in a turned off mode, just outside classA.Circlotron said:
With 2 x idle you'll be safely in classA, even if the load is less than expected, wich it often is
Take a lok at those pictures in that link again.
Let´s say in a class A PP amp we have 1 amp idle. That means both devices are conducting 1 amp. If the PS voltage allows you can get "any" current out to the load but when the load receive 1 amp or more, one of the devices will be off = class AB.
Don´t forgett we have +/- supply and when one device start to close, the other one have to open up to stay at 1 amp "idle".
It´s not like one device closes, the other opens up and the current rises. Think at the two devices as shunts that deals with the idle current.
The idea with 2x idle is not correct.
A class a amp can only output the idle, then it enters AB.
1x idle it is.
/Peter
1x idle it is.
/Peter
Pan,
somehow you must take a look at that picture again. A push/pull amp idling at 1A can put 2A through the load before the lower transistor switches off.
This means that the peak current of an class A push/pull amp is TWICE the idle current giving 50% of max. efficiency.
With a single ended amp this would be 25%
william
william
wuffwaff said:Pan,
william
Lets separate theory from reallity:
Theoreticly William is right, but the conditions there are ideal, unlike reallity, and if you're making a class A amp, you do not want any transistor to get even close to switching off, since no transistor is linear, so how about a compromise here: 1½ x idle, to make some headroom for odd loads
- ClassA question for the enlightened...
