Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#191 | |
Banned
The emitter resistor change will make the GBW lower by a factor close to 33/200 and will increase the distortion by roughly 200/33., so it's not the right thing to do. This also raises the question of why there is a collector resistor in the EF. Was that for power dissipation reasons? With no collector resistor, it can't saturate. Saturation for a PNP happens when the collector voltage is higher than the base. That's how the Baker clamp fixes the problem for the VAS CE stage. It clamps the collector voltage so that in the worst case, the collector is at a voltage the same as the base. When the collector-base junction becomes forward biased (P positive with respect to N), that's what causes the big increase in base current. Think of it as an internal diode between collector and base, with the cathode connected to the base and anode to collector. When this diode becomes forward biased, a big increase in base current occurs. For the BAV21 diode model, try removing the NBV parameter. That's a PSPICE-specific extension also supported by LTspice but maybe not your simulator. |
#192 | ||
Yes. The resistor goes back to the original thread, where we discussed the ways and means to protect the VAS. Pete (PB2) suggested the collector resistor to limit current in the EF. In the sim, when I take out that resistor, the VAS goes into saturation instead, and the current draw is much higher. Also, when I eliminate this resistor in the sim, the Baker clamp diode no longer works. I tried a few different things in the actual amp yesterday, like reducing the emitter resistor (R5) but found I ran into stability problems. This may be due to the way I did these changes - tacking a long leaded resistor in parallel with the existing but I doubt it. I will try the actual amp with R7 shorted and see how it goes. |
#193 | |
I tried that and it made no difference. Same clipping (without the clamp) with or without this resistor. Maybe I should accept what I have. The clamp nicely takes care of the clipping issue; the amp runs ultra stable, even into a capacitive load; simulated distortion is ultra low; reliability seems to be high and sound quality seems to be quite high. After, why fix it if it's not broken? I just completed the first full power trial on this new board. The Baker clamp is just "friction fit" between the leads of the Miller cap and the drivers are not bolted to the heatsink so I don't want to push it. I'll take it off the heatsink later and solder the clamp in semi-permanent place (until I get the BAV21's). The metal tab on the TO-220 is really inconvenient - requiring a plastic shoulder washer to insulate. I like the plastic of the TO-264 and TO-126 much better. No worries about wearing trough the thin plastic of a shoulder washer while installing the screw. |
#194 |
Getting back to the bootstrap topic: I did an interesting test this morning. I needed to put a face on the supposed limitations of this topology. Possibly, all of this has been done before, with much more methodical and exhaustive testing done.
I thought I would measure the voltage at the junction between the top bootstrap resistor, the base stopper to the Q11 driver and the Vbe multiplier. I thought I could just measure the AC voltage here and sweep the frequency up from low to high, taking note of the values. I set the output of my function generator to a sine wave at 20Hz and adjusted the amplitude to give me 10VAC at that junction. I called this my baseline. From here I dropped to 18Hz and took note of the voltage. Then to 16Hz and so on down to 4Hz, taking measurements as I went. I then swept upwards to 20kHz, taking measurements all along the way. To my way of thinking, this effectively maps the linearity of the bootstrap over the swept frequency range. I then did the exact same test with the simulation of this amp, using my RLC mockup in place of the bootstrap cap. The results are below. Top is the charted voltage at frequency of the top bootstrap resistor. The middle is the same in the simulation and the bottom is one over the other for comparison. Thoughts? |
#195 | |
Let me just point out that you seem to be looking for a solution to the current jump as if it is a problem. It would probably help to step back and think about this - you have a high gain amp where the gain is used to correct for distortion/errors in the output - if the output ever cannot track the input with low distortion then the high gain amp attepts to produce a large correction voltage/current. The output cannot follow the input in clipping, slewing, and when it is shorted and therefore the front end tries to produce a large (overload) correction. I believe that it is an oversight not to include R7 as from what I saw the EF and VAS can fail without a protection transistor. I would probably leave in R7 even with an EF/VAS protection transistor. Its important to also look at what the amp does with a shorted output as we discussed in the original thread. You ask about the LTP degeneration resistors - you're lowering the gain when you increase their value and making the front end more linear in overload. However, as Andy pointed out lowering the gain increases distortion. Its a tradeoff. If the amp has high enough slew rate, current limiting during clipping and for a shorted output, and recovers cleanly from overload then it seems that there is no reason to increase the LTP emitter degeneration resistors beyond the value that provides the lowest distortion. They do also make the design less sensitive to diff pair mismatch which is not an issue if you match devices. It is looking good John, like a JE-990 converted to a power amp, with some nice improvements. Cascoded LTP, jcx's trick of bootstraping the LTP, and R7 to improve overload handling/recovery. I remember that you removed the bootstrap to the cascode reference based on simulation results, but I have to wonder if this agrees with real hardware - a minor point. Pete B. |
#196 |
I don't think I can take credit for bootstrapped tail current souces, they predate my birth date
If I were modding what I see in the last schematic I would go for more current gain by using cfp driver stage and high enough bias that it would always be in solid Class A this should increase gain by presenting higher impedance VAS load, the VAS bootstrap would give a higher Z if the C were moved to the lower driver emitter the tail bootstrap R ratio needs to be readjusted to give the new higher current and have the correct divider ratio == feedback divider ratio and while not "simple" I would play with TMC or 2-pole compensation to put more of the (increased) loop gain in the global loop at audio frequencies where it improves both input and output stage distortions |
#197 | |||
R7 stays. Clipping performance is not improved by it's removal. I like how it limits the current through the EF, and by extension, the VAS. Thanks. Everytime I do a new or improve amp project I pick up a few more things. Still, a long way off in my understanding and it shows I expect. What drive me onward are tangible results - I need that working unit in front of me. I also, if I don't mind saying so, have a talent (it must be talent, as I don't actually know enough) for sniffing out the cause of problems. For example: It turns out that this latest board, with all of the tests that were done, had a blown ballast resistor. R17 on Q14 was open. I discovered this when I tried to set up the idle current. The voltage across this one read 408mV, while the one next to it had 15mV. It didn't occur to me that the emitter resistor could be open, and I was getting ready to pull the output, thinking it was faulty. What made me measure the resistance of the resistor? I don't know. I have more faith in the simulator now than I did before, especially where the distortion measurements are concerned. The feed-forward to the cascode would always increase distortion, no matter how I configured it. This was even more apparent when I learned how to use the Fourier analysis, giving much higher resolution. In contrast, the bootstrap to the LTP would lower distortion. It was just a matter of hitting on the correct value for the resistor. Now, the amounts involved are relatively small, but it's all cumulative and it makes up for the small amount of distortion introduced by the Baker clamp (this may or may not be accurate, given my troubles with diodes in this simulator). Quote:
Now you tell me! I guess this is something that i should have known. It makes sense - even though I have selected fast outputs, there would still be a lag between driver and output. I will see about implementing this. Quote:
BUT, Lets save some of those for the sequel! There's V4 to think of... |
#198 |
If you have trouble with sticking on the bootstrap side you can add a diode to clamp the voltage so it can only go outside the rail by 1 diode drop. Then you put one diode in series with the feed from bootstrap circuit to VAS so that the voltage on the driver base/bias spreader is clamped at rail voltage. This prevents saturation in the driver transistor.
#199 | |
Though if you reduced the miller compensation capacitor to bring the unity loop gain frequency back out to where is was the distortion should be relatively unchanged above the dominant pole. In fact it might be slightly less at HF due to the reduced loading on the VAS. Cheers, Glen |
#200 | |
Banned
Here's some experiments I've done in the simulator and what I've found. This used a configuration like the "Blameless" amp. 1) Configuration 1: Input and output stages modeled as ideal controlled sources, and VAS the same as the real design. Vary input stage gm and VAS Cdom simultaneously so as to keep the GBW constant. Look at full power 20 kHz THD. 2) Configuration 2: VAS and output stages modeled as ideal controlled sources, with input stage the same as the real design. The idealized VAS input impedance, transconductance and input DC offset from the rail were made the same as the actual VAS. Vary input stage gm and VAS Cdom simultaneously so as to keep the GBW constant. Look at full power 20 kHz THD. For configuration 1, using reasonable values of Cdom (< 200 pF), the larger Cdom was made, the lower the distortion was. I assume that the increase in the loop gain of the Miller loop due to increasing Cdom was responsible - apparently winning out over the increased VAS loading. For configuration 2, the larger Cdom was made, the larger the distortion was. Clearly this was the result of the capacitive loading of Cdom on the input stage. Input stage distortion was very low, but this wasn't achieved until I used bootstrapped cascoding of the input stage. Now suppose the whole amp were simulated, starting with larger than usual input stage emitter degeneration and small Cdom. Suppose you simultaneously decrease emitter degeneration and increase Cdom to keep GBW constant. My guess was that the 20 kHz full power THD would keep decreasing up to the point where input stage distortion started to overtake VAS distortion. Then, as further decreases in input stage emitter degeneration were made, the distortion would begin to increase again. This is exactly what happened. I stepped Cdom over a list of standard capacitor values, recomputing input stage RE at each step. There was a combination of Cdom and input stage RE that gave the best 20 kHz THD. For larger or smaller Cdom (with RE adjusted appropriately), the full power 20 kHz THD increased. So I ended up using the Cdom and RE that were optimized in this way. For this specific design, Cdom was 68 pF - nothing at all radical. |
Thread | Thread Starter | Forum | Replies | Last Post |
Need circuit board layout for STK4142II plaese | steve101 | Chip Amps | 1 | 2nd August 2005 09:35 AM |
New To Site? | Need Help? |
