Hi, everyone.
I am looking for the ETI 470 amp, ETI 471 pre amp Schematic and PCB layout. it used the philips BDV64/64 output transitors. published in May 1979 Can any one help. Many Thanks |
#2 |
Here you go...
http://www.4shared.com/file/63555882...2/ETI_470.html |
#3 |
Many thanks for posting it Filby
#4 |
Just a quick note as I build this power amp many years ago.
The amp sounded great but was unreliable. This proved to be because the specified power supply voltage was just too high. In the original 1979/80 version the power transformer was 30-0-30, and could cause break down of the input devices. I note in this version it's 28-0-28, I ended up using 25-0-25, as a safe option. I also added some over current protection set to 3 amps, which saved the output devices from thermal runaway when I didn't get them perfectly flat on the heat sink. |
#5 |
i would built a think like that is for fun ....
in any case you decide to do so keep in mind that your outputs have to be made my the same mom like you cannot have a bdv 66 from philips and a bdv 67 from ST ... the reason is that they may say that they are bdv 66 or 67 but due to the construction inside might have diference ( not matching ) inside depending on the part number ...... any way i would go for ON SEMI MJ 11015-16 FAR MORE BETTER AND ROW BUST ..... to symon the above reason is NO 1 reason for thermal runaway cause in this case you adjust idle to specs but that apply only when amp is on idle if you power it up then things are pretty much messed up measuring voltage drop on every emmiter resistor might be some help cause you may find some diference there but still that cannot tell you much since even if you do find a diference there is nothing you can do about it ......its just an indication ..... regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#6 |
I built one of these too, but I used TIP transistors for the outputs. Transformer was 56VCT, with 26,000 uF per rail for a stereo amp.
ETI (though not the Canadian edition) later published an input buffer board for this amp since in the stock form it has a pretty low input impedance. I've got a photocopy someplace, which I ought to scan. I blew a channel once by shorting the speaker cable, and more recently blew both channels when I used it as a DJ monitor amp. I'm leaning towards filling the box with LM3886's instead... |
#7 |
SHELF A DX AMPLIFIER FROM CARLOS DESTROYER X
you are simply going to love it .....3886 is fine but not so nice as dx
#8 |
oh no, DX Standart VS 3886 ?
i have build a DX Amp, sound to superb if compare to lm3886. JUST GO FOR DX AMP! by Carlos MERGULHAO. |
| looking for a pre-amp schematic | steamPunk | Tubes / Valves | 3 | 3rd August 2008 01:49 PM |
| DBX 500 schematic | d3imlay | Solid State | 0 | 2nd August 2008 05:12 PM |
| Need bat vk-200 schematic | krezov | Solid State | 1 | 24th January 2008 08:05 PM |
| F3 schematic | kenev | Pass Labs | 2 | 24th January 2008 03:24 PM |
| SVP-PRO schematic | surfer156 | Tubes / Valves | 3 | 17th July 2007 02:28 PM |
| Page generated in 0.09317 seconds (75.97% PHP - 24.03% MySQL) with 10 queries |
