Old 7th July 2008, 06:42 AM   #21
Mooly's Avatar
Hello Lumba Ogir and SandyK,
I have built Dougs designs, his blameless Class B being one of them. It was built on the official PCB,s and built EXACTLY to the construction details supplied, no component substitutions at all.
The wiring followed Dougs recommendations also included with the PCB's. It was used with a passive pre amp.
I still have the amp and dragged it out about 6 months ago to have another listen as my listening room had been redesigned and I now had much better speakers B&W703's.
I have to agree with your comments-- I found it "boring", there was no "soundstage" it was all two dimensional, instruments were "cold" no warmth or vibrancy. Going back to my MOSFET design was truly a revelation.
I would further add that in my experience designs like Dougs, and there are many that use similar topologies, do have this "same sound" about them.
Without wishing to detract from Dougs work-- and his knowledge of the subject is second to none I believe-- my conclusion is that technical perfection is not the whole answer to that "Magic" factor that some designs seem to have.
Regards Karl
Old 7th July 2008, 06:55 AM   #22
sandyK is offline sandyK  Australia
Default Whyt does a Class A distortion increase with frequency ?
Mooly
Do you have a schematic of the actual amplifier you constructed, or does it appear in Issue 2 of the D.S. book ? If so, where ?
My email address is alexkethel@optusnet.com.au
Several DiyAudio members from Sydney have been able to make kits based on the D.S. topology really sing, with large 3D soundstages and a natural sounding warmth. Especially the Class A variants, however, Class AB versions can also be made to sound markedly better.
SandyK
Old 7th July 2008, 10:48 AM   #23
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by tcpip
is crossover distortion really the biggest source of distortion by far in a well-designed Class B amp?
Take a look at the Class AB power amp designs that do not include the output stage in the NFB loop.
Old 7th July 2008, 11:01 AM   #24
tcpip is offline tcpip  India
Originally posted by Nelson Pass
1) Possibly - I haven't thought about it that much because it's not
particularly important to me. My definition of a well designed amp
is a little different than Self's.
Accepted. We all know Self's approach is primarily driven by quantitative measurements.
2) If you mean Class B (with no bias at all), generally yes.
I don't know about the "no bias at all" bit. I meant a Class B amp with bias carefully adjusted to minimise THD at a few Watts output. This means there's some bias current flowing through the OPS devices, right? Is that what you mean by "no bias at all"? If yes, then that's what I meant too.
3) Take a look at the article "Leaving Class A" at www.passlabs.com.
Found the PDF, am reading it. Thanks a lot.
4) Yes, as I mentioned previously.
5) Yes, but it varies depending on the design.
I'll read your article and then return to this discussion. Thanks a lot. I'm pretty sure there's stuff in there I'll find very interesting.
Old 7th July 2008, 11:45 AM   #25
traderbam's Avatar
Default Hearing is believing
Originally posted by sandyK
In my experience they sound fine,but unexciting, with a relatively small soundstage. They are very clean sounding, which some people may not like. Neither do they have an artificial warmth.
SandyK
And yet....
And so...
...that "Magic" factor that some designs seem to have.
What's the alternative conclusion that doesn't require magic?
Old 7th July 2008, 12:07 PM   #26
Mooly's Avatar
Whats the alternative conclusion --- that's easy --- Listen to an amp that you really enjoy. One that makes the music "come alive"
The conclusion is that many people don't seem to like "the piece of wire with gain" in much the same way that musicians prefer one instrument over another. An old Stradivarius or Testore wasn't designed with computer simulation, yet a cheap modern instrument probably was, and is probably technically superior. But which would you rather play ??
Old 7th July 2008, 12:21 PM   #27
Read the article. It was an eye-opener. I didn't know Class A OPS had such low open-loop distortion. I think I'll go away and think some more about this entire Class A HF distortion thing.
What measured closed-loop distortion would you get with a high-bias Class A, if you applied a lot of GNFB? Do you have any distortion graphs for such cases handy? I know you don't prefer such amps, but I'm just curious to know what the "numbers" look like.
Old 7th July 2008, 12:27 PM   #28
traderbam's Avatar
Mooly,
No, no. Keep your wits about you. You are drifting into AKSA territory now.
You listened to Self's design and found it lacks magic. You assumed Self is a leading expert at making "technically" accurate circuits. Therefore, you've concluded, that technically accurate circuits don't sound great.
Are you sure?
Old 7th July 2008, 12:58 PM   #29
Default Why does Class A distortion increase with frequency?
Not so long back, Silicon Chip magazine published a 20W/Ch Class A design which they stated was based around the work of Douglas Self. They quoted a typical distortion figure of .0006% at around 10W. (20HZ -20KHZ) This was WITHOUT close matching of devices.
SandyK
Old 7th July 2008, 01:08 PM   #30
Default Re: Why does Class A distortion increase with frequency?
Wow. That's impressive measured performance at 20KHz. Found the article. Will read more details at leisure. Thanks for the pointer. From some comments in some forums, it seems it's basically Self's Blameless, biased into Class A the way he'd demonstrated it in his book. Is this the case?
Marshall AVT 50 preamp gain/distortion increase Voland Tubes / Valves 3 27th November 2010 01:05 PM
HOW TO increase the class-d's gain? aobuke Class D 3 13th February 2009 08:17 PM
high frequency distortion paul_peraic Parts 2 7th May 2008 03:48 PM
Turntable High Frequency Distortion Sibilance Signal Analogue Source 1 8th January 2008 06:09 PM
How to increase Car Radio Frequency ohynot Car Audio 2 11th March 2005 06:41 AM
Page generated in 0.11598 seconds (85.46% PHP - 14.54% MySQL) with 11 queries
