Old 22nd May 2008, 02:52 PM   #1
Onvinyl's Avatar
Default Discrete cfp (op-)amp
I'm looking for (basic) discrete cfp amp circuits to play with and examine. For example, a schematic of the AD811 (but I don't think it's published?)
Tietze/Schenk have a discussion of a transimpedance opamp which is the starting point for me.
thanks in advance,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 22nd May 2008, 05:08 PM   #2
You think you can duplicate the function of an op amp by reproducing its internal circuit?
Don't ever think of it! Integrated circuits rely their operation in very well balanced transistors characteristics, with they achieve by making them into a single chip (same dopage) and close proximity (well termal mayching)
No way a discrete duplicate can even function.
Old 22nd May 2008, 05:32 PM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
I don't have any examples, but I'm here to say that it is possible to develop descrete op-amps. How do you think SS power amplifiers are mostly designed? A common three-stage SS push pull amplifier done in discrete topology with negative feedback loop and differential pair is really a power op-amp.
I can't say I've ever tried to duplicate an existing op-amp, you will not be able to easily achieve similar operational characteristics. You can make discrete op-amps if you know how to design these kinds of things though. There are cases where this is useful if you need the circuit to do things the pre-made ICs can't do.
Generally, though, the op-amp in its IC form from major suppliers will outperform anything one can build discretely by leaps and bounds from the standpoints of distortion, noise, offset, speed, etc depending on the kind of op-amp in question.
Old 22nd May 2008, 05:41 PM   #4
Onvinyl's Avatar
I agree to both of you. There is no point in reversing an IC and hoping to outperform it's numbers. I'm looking for examples of transimpedance circuits to try discrete circuits. I *do* have hopes for good sound, anyway....
thanks,
Rüdiger
Old 22nd May 2008, 05:47 PM   #5
Duo's Avatar
Do you have a copy of The Art of Electronics, but Horowitz and Hill? Especially the second edition?
This shows you more or less what you need to know about all sorts of circuitry. It's one of the few 'bibles' of electronics and everyone in the field should have it on hand.
http://www.ecircuitcenter.com/Circui...tov/opitov.htm
The link above shows the basic example of a transimpedance amplifier implemented with a normal opamp.
http://mysite.du.edu/~etuttle/electron/elect21.htm
This link shows a Norton amplifier, which is a true differential transimpedance amplifier.
You could build either type on the breadboard with discrete parts if you are stubborn enough; I know I am since I do so from time to time for fun.
Old 22nd May 2008, 05:47 PM   #6
Juergen Knoop's Avatar
sorry, I was wrong
Old 22nd May 2008, 07:38 PM   #7
Onvinyl's Avatar
the source from Walt Jung was way more comprehensive than I remenberd.
here is pretty anything one might want to know...
Rüdiger
Old 22nd May 2008, 10:39 PM   #8
nigelwright7557's Avatar
Default Re: Discrete cfp (op-)amp
thanks in advance,
Rüdiger
Top engineers have put a great deal of thought and expertise into an op-amp.
Why not just take one off the shelf and use it yourself ?
My power amp designs use a very simple op-amp type cct which has much fewer transistors than an internal op-amp.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 23rd May 2008, 12:57 AM   #9
unclejed613's Avatar
i'm working on an amp that basically uses a discrete op amp for the input stage and VAS. the "op amp" will basically be on a separate module, and the driver/ output stage will be on the main board. the use of the discrete op amp allows the amp to be scalable (within the voltage limits of the "op amp") simplifying the amp design. the "op amp" also has (like many op amps) pins for compensation caps, so the compensation can be tailored for various output device junction capacitances. the module can also be used as a standalone high voltage op amp for other applications.
i've also seen that Cirrus/Apex now has a dual "op amp" chip (with a package like an LM3886) that can operate at +/-100V rails. it's actually designed for driving piezo elements, but i'm thinking of trying it out as an audio amp driver.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 23rd May 2008, 07:01 AM   #10
nelsonvandal's Avatar
I've set up some opamps in LTSpice. They simulate very well. I can post them tonight CET. AD829, AD797, LT1363 etc. I've not made any of them in real life, just some simple "basic" opamps. I did try CFP on the output stage with oscillation as reslut. With my limited experience I think the typical "diamond buffer" is outstanding as output stage. I guess it's not a coincidence that "all" good opamps use this like the three mentioned above.
I was on a quest for a perfect portable headphone amp and was never satisfied with monolithic opamps. People said a discrete battery powered amp was "impossible", but they're dead wrong.
My first discrete amp danfo098 Solid State 60 30th July 2009 05:40 AM
discrete op amp unclejed613 Solid State 24 5th January 2007 09:49 AM
Ic Vs Discrete AR1 Parts 4 29th April 2005 02:09 PM
Page generated in 0.10793 seconds (81.40% PHP - 18.60% MySQL) with 11 queries
