Old 21st May 2008, 06:51 AM   #1
Default TL071 opamp circuit needed
hi,
i need to bost my input gain for my amp. i have seen that i can use opamp to bost the signal from cd player.
it gose like this....CD player-->--OPamp---> amp
i have TL071 ic for opamp. i need the circuit design for simple way to build opamp.
thank you.
Old 21st May 2008, 07:10 AM   #2
Mooly's Avatar
How much gain do you need ? what supplies have you got ?
You need 2 opamps or 1 dual TL072. See image.
The second one is phase inverting but this configuration can sound better to me. You can add a small ( around 4.7 PF ) cap across the 47 K ( This is where you need your 'scope )
Old 21st May 2008, 09:04 AM   #3
hi mooly,
thank you for your circuit. i want to use it for a gain boster for amp. now i can calculate the gain for the amp.
for Precs-I, what us the highest gain should be? do you know?
thank you for help.
Old 21st May 2008, 09:21 AM   #4
AndrewT is online now AndrewT  Scotland
the highest signal from a CD player is about 2Vac.
If you have a 100W into 8r0 amplifier then the highest signal to the speaker is 28.28Vac.
The gain you need is 14.1Times (+23dB).
most amplifiers are set up with a gain of between +20dB and +36dB.
You don't need any more gain in the preamp to achieve maximum power into your speakers.
You need attenuation.
regards Andrew T.
Old 21st May 2008, 10:38 AM   #5
Something is very wrong if you need to boost a CD players output.
/sreten.
Old 21st May 2008, 10:52 AM   #6
Mooly's Avatar
Maybe they are quiet CD,s
Old 21st May 2008, 12:43 PM   #7
hi,
if my amp operate with my mobile phone. the sound is very strong and loud as it should be by the wats but when i attach the cd player it's gets flat and low sound like 50% less then mobile phone was used. so i was thinking may be it cause by the gain is too low for the amp.
thank you.
Old 21st May 2008, 12:50 PM   #8
ssmith is offline ssmith  France
what CD player are you using?
Old 21st May 2008, 12:58 PM   #9
PMA is offline PMA  Europe
PMA's Avatar
I just used one for a DC servo.
Old 21st May 2008, 01:07 PM   #10
hi,
i likie to thanks all of you. For the gain control circuit calculation
RF=47k
Rin=22k
Gain= RF/Rin
Gain=47/22 = 2.136db?
thank you.
Simple 'treble cut' opamp circuit needed. HankMcSpank Solid State 10 20th July 2008 07:03 AM
Can anyone help with this opamp circuit? lt cdr data Solid State 4 20th May 2005 10:12 AM
Transistor/opamp circuit soundNERD Chip Amps 12 15th September 2004 02:16 AM
Need Opamp Mic Preamp Circuit JojoD818 Solid State 15 2nd August 2003 04:15 AM
Page generated in 0.10753 seconds (80.20% PHP - 19.80% MySQL) with 11 queries
