TL071 opamp circuit needed
Administrator
Joined 2007
How much gain do you need ? what supplies have you got ?
You need 2 opamps or 1 dual TL072. See image.
The second one is phase inverting but this configuration can sound better to me. You can add a small ( around 4.7 PF ) cap across the 47 K ( This is where you need your 'scope :) )
the highest signal from a CD player is about 2Vac.
If you have a 100W into 8r0 amplifier then the highest signal to the speaker is 28.28Vac.
The gain you need is 14.1Times (+23dB).
most amplifiers are set up with a gain of between +20dB and +36dB.
You don't need any more gain in the preamp to achieve maximum power into your speakers.
You need attenuation.
Administrator
Joined 2007
Maybe they are quiet CD,s :)
hi,
if my amp operate with my mobile phone. the sound is very strong and loud as it should be by the wats but when i attach the cd player it's gets flat and low sound like 50% less then mobile phone was used. so i was thinking may be it cause by the gain is too low for the amp.
thank you.
space2000 said:
hi,
thank you.
No it is simply because the phone puts out higher voltage than the CD player.
If with the CD player you can turn the amp up and make it clip or distort, you simply don't need a pre-amp.
Administrator
Joined 2007
Hi Space,
What supplies have you available ? You can make either run off a single supply ( with a few more bits ) if you have to, but the split supply is better.
Are you building this into that amp you posted the pics of ?
If you are it's easy, the TLO71 or 72 use so little power that a very simple resistor and zener is all you need for each rail supply.
Remember that R1 sets the input impedance so choose this first then work out what gain you need. The 22K and 47K should be fine though.
If you want the gain expressed as a ratio i.e. db, for the non inverting it is;
20 log*(RF+R1/R1)
And for the inverting it is;
20 log*(RF/Rin)
Are you putting a volume control after the Op Amp. Remember any switch on noise as the circuit settles will be amplified and add to any noise produced by the amp at switch on.
Administrator
Joined 2007
Just to clarify as I have used different terms ( just to confuse you :D ), the input impedance is set by the total value of the input resistance for the non inverting one, so that is the two 100k's in parallel. 50K therefore, input impedance for this one.
The inverting input impedance is determined by Rin. So thats 22K
hi mooly,
thank you. problem was equalizer setup for output gain.
now it is ok.......
this amp is ok now... thanks for your gain circuit, i will need it for future.
i still want to try another one to build like "class A amp" i never done it b4, using transistor. it can be low wats like 50 to 100w nice to me.
if you have any simple way to build class a amp pls post the circuit to my email address or here.
mitoo_singapore@yahoo.com
best regards
michael
