Hi Guys,
how can i check the linearity of my circuits? Thank you! Maxpou |
#2 |
A THD analyser.
Just because you can't hear it doesn't mean no one can. |
#3 |
A triangle waveform generator and a fast CRO for a visual indication
#4 |
Thank you for answers!
but what's CRO? Thank you! Maxpou |
#5 | |
The triangle waveform generator is a good idea. And it is easy to build a fairly good one. (Do a search at national.com for "tri-wave generator".) To check linearity, you would want to make sure that vout/vin is constant, for all expected values of vin. Checking linearity with a triangle waveform for vin is easy: If vout is also a triangle shape, the system is linear versus input voltage. But if the rise or fall portion of the output waveform is curved, or worse, then the system is not linear. You would probably want to check that that is also true when vin is changing, for all expected rates of change of vin. The triangle generator would also handle that, if it had variable frequency as well as amplitude. |
#6 |
interesting topic! What is the ballpark of THD-N when the triangle-wave is visible deformend? Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#7 | |
That's a difficult one, as a perfect triangle is a sine wave + 30% 2nd harmonic. Plus 4th, plus 6th, plus.... Just as a perfect square wave is a sine wave + 30% 3rd harmonic. Plus 5th, + 7th + ... That is why a tringle is a very crude way to guesstimate linearity. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#8 |
Should be said that depending on repetition frequency, the triangle may be distorted in shape, as no audio circuit works from DC to infinity. HF corner results in triangle corner rounding, LF corner results in a "bow" shape of triangle. It will work only for repetition freq. in the midband.
#9 |
Is the triangle trace any better than the classical XY trace of I/P - O/P sinewave. Loss of linearity is immediately apparent by curvature of the (ideally) straight line at midband, or lack of ellipticity elsewhere (and shows phase to boot!)
This is how I try to detect slew rate limiting. Does that make sense? Brian. |
#10 |
A "bow" shape (red curve), due to low frequency corner. Nothing in common with non-linearity.
| DAC linearity test CD | oshifis | Digital Source | 52 | 22nd May 2012 11:27 PM |
| Air-spring non-linearity, causes? | thadman | Multi-Way | 17 | 26th May 2009 07:27 PM |
| improve the linearity | E007 | Solid State | 1 | 3rd May 2004 09:23 AM |
| Non-linearity of wattage to SPL... | JoeBob | Everything Else | 5 | 21st February 2002 07:47 PM |
| Page generated in 0.09983 seconds (78.13% PHP - 21.87% MySQL) with 11 queries |
